Red cosworth
#81
Alrite Colin man, long time no see, this red saph came from down south somewhere, had a private plate on it for a while accordin to history, last 10 mots done at GGR and over 16 grand of GGR receipts for work and parts on engine and runnin gear to do the 8 injector conversion and everything else,
#82
Who mentioned anything about street name in sig?
#84
This is what the GGR receipts are for
1993 SIERRA COSWORTH 4X4 RADIANT RED 450BHP VERY RARE ONLY 9 EVER MADE IN THIS COLOUR.
THE CAR HAD THE ENGINE REBUILD AT GRAHAM GOODE WITH 8 INJECTOR CONVERSION AND WATER INJECTION COSTING Ł16655.05 RECEIPT FOR THIS
WORK CARRIED OUT WAS HAS FOLLOWS
ENGINEERING SERVICES
TO RELINER, REFACE, REBORE &PLATEAU HONE CYLINDER HEAD BLOCK Ł350.00
TO GAS FLOW CYLINDER HEAD AND MATCH MANIFOLDS ETC. Ł645.00
POLISH CRANK SHAFT JOURNALS Ł40.00
TO SUPPLY AND FIT NEW EXHAUST VALVE GUIDES AND RECUT SEATS ETC Ł112.50
TURBOCHARGER OVERHAUL USING NEW BEARINGS AND SEALS
ENGINEERING SERVICES TOTAL Ł1397.50
ENGINE PARTS USED
GGR 007 HIGH CLAMP CYLINDER HEAD STUD & NUT KIT Ł280.00
GGR 821 WRC CYLINDER HEAD GASKET Ł360.00
GGR ENGINE GASKET SET (LESS HEAD GASKET) Ł125.00
FRONT DIFFERENTIAL O RING SEALS Ł4.28
SUMP BUNG AND SEAL Ł4.00
YBO 051 VALVE SPRINGS X 16 Ł230.40
1668305 THERMOSTAT Ł34.00
GGR 322 BD 14 INLET CAMSHAFT Ł234.00
GGR 323 BD 14 EXHAUST CAMSHAFT Ł234.00
GGR 298 ADJUSTABLE ALUMININIUM CAM PULLEYS X2 Ł122.00
LIGHTWEIGHT CAM FOLLOWERS X 16 Ł207.20
GGR CAMBELT Ł39.00
1639176 CAM BELT TENSION PULLEY Ł43.37
GGR 425 EXHAUST MANIFOLD WASHERS X 16 Ł2.20
GGR 424 EXHAUST MANIFOLD METALLOCK NUTS X 16 Ł48.16
6184363EXHAUST MANIFOLDS STUDS X 16 Ł28.80
AGPR 902 P SPARK PLUGS X 4 Ł33.12
ATN 10 METALLOCK NUTS X 7 Ł7.00
GGR254 + 0.25MM PISTONS 7.2:1 COMPRESSION Ł594.00
1552834 AUXILIARY SHAFT BEARING Ł5.49
PP 3511 BLOCK CORE PLUG SET Ł9.46
1665133 FLYWHEEL DOWELS X 3 Ł1.77
1639179/1642754 -0.25MM MAIN BEARING SHELLS Ł82.50
1639162 - 0.25MM BIG END BEARINGS Ł58.88
6033895/6018218 THRUST BEARINGS Ł9.08
6165923 CRANKSHAFT WOODRUFF KEYS X 2 Ł1.36
GGR 461 CLUTCH SPIGOT BEARING Ł6.95
YBO 582 OIL PUMP Ł164.27
PP3916 GROUP A OIL PUMP SPRING Ł10.00
PP 5288 OIL PUMP SPRING RETAINER Ł10.00
STU 3 EXHAUST DOWNPIPE SUDS X3 Ł1.20
DDB 882 DISTRIBUTER CAP Ł7.44
GGR 544 ROTOR ARM Ł9.45
OIL PRESSURE LAMP SWITCH Ł3.41
GGR 500 CRANKSHAFT POSITION SENSOR Ł38.84
EFL 90 OIL FILTER Ł3.33
AUXILIARY BELT TENSIONER PULLEY BEARING Ł9.78
A P RACING GROUP N CLUTCH COVER CP3380.6 Ł171.45
A P RACING SPRUNG CLUTCH CENTRE CLUTCH PLATE Ł148.45
GGR 443 CLUTCH RELEASE BEARING Ł20.49
GGR 635 SILICONE BYPASS HOSE Ł3.30
STAINLESS STEEL HOSE CLIPS Ł11.01
ENGINE PARTS TOTAL Ł3469.44
8 INJECTOR CONVERSION PARTS
WRC ESCORT COSWORTH INLET MANIFOLD Ł286.05
WRC ESCORT COSWORTH FUEL RAIL Ł211.20
FUEL PRESSURE REGULATOR Ł175.00
PIPE ADAPTORS FOR ABOVE Ł9.90
FDB 914 INJECTOR SAFETY CLIPS X 4 Ł4.80
0 280 150 803 BOSCH FUEL INJECTORS X 8 Ł620.00
GGR 528 120 LITRE / HOUR FUEL PUMP Ł222.48STRAIGHT FITTING Ł11.47
HOSE Ł6.38
HOSE END FINISHER Ł6.81
ADAPTOR Ł12.42
GGR 523 FUEL FILTER Ł21.27
MODIFY ECU FOR 8 INJECTOR OPERATION & BOOST CONTROL Ł895.00
ADDITIONAL INJECTOR SUB LOOM Ł75.00
SPECIAL 8 INJECTOR EPROM Ł300.00
8 INJECTOR CONVERSION PARTS TOTAL Ł2858.08
ENGINE INSTALLATION PARTS
GGR 060 INDUCTION KIT TRUMPET Ł48.00
GGR 064 INDUCTION KIT AIR FILTER Ł59.57
GGR 2 PORT SEPERATOR & CATCH TANK BREATHER SYSTEM Ł608.05
GGR HIGH PRESSURE COOLING SYSTEM (LESS RADIATOR) Ł454.17
GGR 702 SHORT SILICONE HEATER HOSE Ł15.75
GGR 703 MEDIUM SILICONE HEATER HOSE Ł32.73
GGR 704 LONG SILICONE HEATER HOSE Ł39.95
6605902 HEADER TANK HOSE Ł6.16
GGR 080 DUMP VALVE BUNG Ł5.00
GGR 264 DUMP VALVE RELOCATION SILICONE HOSE Ł69.95
STAINLESS STEEL HOSE CLIPS Ł22.04
ENGINE INSTALLATION PARTS TOTAL \31361.37
WATERINJECTION SYSTEM
WATER INJECTION PUMP Ł280.00
WATER INJECTION SPRAY VALVE Ł9.78
GGR 082 WATER INJECTION RESERVOIR Ł300.00
WATER INJECTION RELAY Ł5.31
ELECTRIC CABLE ETC Ł5.80
3225-10052 WATER INJECTION HOSE Ł4.25
WATER INJECTION PUMP RUBBER MOUNTS Ł13.56
WATER INJECTION PARTS TOTAL Ł622.86
TRANSMISSION PARTS
REAR DRIVESHAFTS (PAIR) Ł450.00
COMPLETE FORD GEARBOX & TRANSFER ASSY Ł762.00
OVERHAULED REAR DIFFERENTIAL ASSEMBLEY Ł445.00
REAR PROPSHAFT ASSEMBLY (FORD) Ł269.36
TRANSMISSION PARTS TOTAL Ł1926.35
OILS ETC
GGR SYNTHETIC ENGINE OIL Ł28.00
MT 75 GEARBOX OIL Ł15.30
SX 75/90 GEAR OIL Ł13.60
ANTI FREEZE Ł12.00
FUEL RUNNING IN Ł40.00
OIL ECT TOTAL Ł108,90
LABOUR CHARGES
O STRIP, INSPECT RE BUILD &RE FIT ENGINE Ł2250.00
(50HOURS @45) STANDARD CHARGE
TO FIT WATER INJECTION SYSTEM NO CHARGE
TO FIT COOLING, BREATHER AND INJECTION SYSTEM NO CHARGE
TO FIT ADDITIONAL 8 INJECTOR PARTS NO CHARGE
TO FIT OVERHAULED REAR DIFFERENTIAL,DRIVEHAFTS SND PROPSHAFTS ETC. 4 HOURS@ Ł45.00
LABOUR CHARGES TOTAL Ł2430.00
INVOICE TOTALS
ENGINEERING SERVICES TOTALS Ł1397.50
ENGINE INSTALLATION PARTS TOTAL Ł1361.37
WATER INJECTION SYSTEM PARTS TOTAL Ł622.86
TRANSMISSION PARTS TOTAL Ł1926.36
OILS ETC TOTAL Ł108.90
INVOICE SUB TOTAL Ł14174.51
VAT @17 1/2
TOTAL Ł16655.05
#85
Made in Scotland
Jesus christ that's some fucking bill. I think I'd take a heart attack if I was faced with a 16k bill for engine work on my car when I went to collect it.... still can't believe they're selling it as an 8-injector conversion and keeping the standard intercooler too?! ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Any pictures of the car yet?
Cheers,
Grant
Cheers,
Grant
