rwd cvh front engined car?
what gearbox could you use on a cvh turbo engined car front engine rear drive?sure ive seen a ford pop or summit that uses this set up! T9?would a T5 work?just curious
the T5 aint good for power?rad what u smoking?swiss crack or summit! what about a 1.8 zvh motor?can these be used with a t9 or t5?talking less than 300bhp what would work?
Saph 2wd will fit ,
need a slihtly shorter bell housing tho , or fit a hydrolic clutch .
I just had a thought , use a 1800 siera bell housing ( if its a shorter one ) or the flywheel , as this may be spaced out a little further
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
i was gonna do this a while back ( RWD CVH turbo),
but by the time i managed to sort a rwd shell out i had seen the light ,
2.1 16v zetec ,
i recon 300 HP zetec in a RWD escort is gonna be loads of fun , a hell of a lot lighter than a cossy lump .
2.1 16v zetec ,
This is what was gonna happen with my Fiesta, the end transmission spec decided was a 2wd MT75 box with 4x4 Cossie internals. The only problem I was having was the flywheel / clutch combo - wanted a Cossie clutch for a nicepedal action but needed a custom flywheel built up.
Ben
Ben
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
wheelwizardrefurbs
04-08-2015 06:23 PM
