oil temp gauge help
as above i have this gauage fitted in my cra was like that when i got it and there is the wire for it coiled up next to my battery thats it! what do i need to buy to get it working how much and where from cheers!
http://www.burtonpower.com/tim036.html
You will need a switched live feed to it and then there will be another connection leaving the gauge which connects to your sender.
Edit to say the "Coiled wire by the battery" will most likely be the live, this is what needs to be live with ignition.
Martin
Martin
You should already have the sender fitted and connected, so in theory you just need to splice that wire into a live feed which is live with ignition. You could splice into the stereo live but then it will come live with the radio, personally I don't like this as just like that to be for stereo, nothing else.
It sounds as if some numpty before hand just connected it to the battery which in fact you could do to test if the gauge works... Simply touch this wire onto the + terminal of the battery and start the car (Make sure it actually is the live to the gauge though)
Martin
Martin
deathrider666
28-09-2015 06:12 PM
