URGENT HELP NEEDED!!!
Old 29-01-2005, 01:40 PM
rsjohn
rsjohn's Avatar
Default URGENT HELP NEEDED!!!
Im in the middle of fitting my secs monitor in my 4x4 cosworth and have come across 2 problems;
1. it says i need to connect the grey wire to pin 25 on cos connector loom but not got grey wire in the loom with secs
2. the white wire connects to pin 15 on cos connector loom but that wire joins into another wire then is a big black wire
Has anyone got a pic of the back of their secs so i can see connections and wires please?
And how did they connect the white wire, pics if pos please?
John.
Old 29-01-2005, 02:01 PM
SPADGE
SPADGE's Avatar
John what colour are the wires from your monitor to the loom?
Old 29-01-2005, 02:04 PM
rsjohn
rsjohn's Avatar
black, red, green, blue, yellow, white
John.
Old 29-01-2005, 02:07 PM
the saint
the saint's Avatar
the grey one is for the revs.........
Old 29-01-2005, 02:09 PM
SPADGE
SPADGE's Avatar
Green pin no 17
White pin no 15
red pin no 20
yellow pin 31
blue pin no 29
Thats what i have anyway!
Don't know about the white wire prob but i would guess you need to solder a wire to the white before it goes into another??
Old 29-01-2005, 02:11 PM
SPADGE
SPADGE's Avatar
Just a thought these connections are from an early SECS monitor so if you have a newer one with rev counter etc...yours may be different!
rsjohn
rsjohn's Avatar
i know but i have no wire for it!!!
John.
Old 29-01-2005, 02:14 PM
rsjohn
rsjohn's Avatar
How will i know if early secs or not?
John.
Old 29-01-2005, 02:15 PM
SPADGE
SPADGE's Avatar
If it hasn't got a grey wire then its more than likely an early one as these didn't have a rev counter!
If your wires are the same colour as what i listed then wire them that way!!
Old 29-01-2005, 02:23 PM
rsjohn
rsjohn's Avatar
Cheers spadge.
So if i have the early type i wont have a revs bit then?? Is that all i wont have?
John.
Old 29-01-2005, 02:30 PM
rsjohn
rsjohn's Avatar
What would happen if i put a piece of wire and connected that pin on secs to pin 25 on ecu loom? would the revs bit work then?
John.
Old 29-01-2005, 03:39 PM
SPADGE
SPADGE's Avatar
If the monitor you have wasn't made with a rev counter facility then you can connect as amny wires as you like and you still won't have one
I take it this monitor was s/hand?
Old 29-01-2005, 03:49 PM
rsjohn
rsjohn's Avatar
Yes was second hand, got it working now apart from the white wire which is for map sensor on pin 15.
See other thread.
John.
Old 29-01-2005, 08:07 PM
rsjohn
rsjohn's Avatar
Sorted now cheers.
john.
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
col93saphcos
07-08-2015 03:21 PM
Quick Reply: URGENT HELP NEEDED!!!
