is there a cheaper way than this?
seems a complete rip off,
http://www.pumaspeed.co.uk/showdetai...?productID=405
i want bigger rear brakes but this takes the piss!
is there any other routes to go down?
my rear discs look to small, with my 330mm fronts on the way they will look stupid. lol
was thinking of using my 300mm st170 disc's on the rear???
it's a focus btw
it's a focus btw
Resident Wrestling Legend
so all they are doing is supplying you with a set of 2wd cossie rear discs, and some brackets to space them out?
you can get a set of discs for buttons and seeing as the 2wd cossie uses the same calipers as every other sierra/granada with rear discs, they ain't exactly rare
and a bracket that can be made for a few quid
all to give you smaller brakes?
im guessing you can buy that carrier from ford?
Quite easy on a Focus. Get some st170 hubs, they will fit on a standard disc subframe, and bolt on the 170 callipers. The hand brake cable will be a bit of a stretch, but I have one you can have if you'll pay the postage. Might be cheaper to get it from the scrappy at the same time as the other parts though.
NC53
13-09-2015 03:05 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
saph in dorset
14-08-2015 10:10 AM
