screamer pipes and track days?
is there anyway of shutting them up as im going to need to fit an external wastegate but love the sound of a screamer pipe so wanted to have one instead of routing it back into the exhaust but its been mentioned i wont get on track with it?
Dreamer
you cant blank it off for track days as you would be blanking of the wastegate as well,
only way i can think of is to have a external wastegate routed back to exhaust as normal, but with a switchable cutout like you get for exhausts to use on the street.
just weld the wastegate flange on to a short piece of pipe and weld it into the down pipe with a plate welded over the centre hole so its blanked off , then just buy another wastegate flange so you can run it as and when you want to with the screamer pipe.
before you buy the wastegate ask them to send you the outlet weld on ring.
cheers paul
cheers paul
could be bollocks
JoeyBoyden
04-01-2024 02:36 PM
Rsmat
42
01-09-2015 09:39 PM
track.focus'd
12-08-2015 05:53 PM
