welding a diff?
Old Oct 22, 2010 | 03:32 AM
weesteve's Avatar
weesteve
Default welding a diff?
ive just bought a ford sierra 2l saff.
ive heard about this welding up the diff?but whats the pros and cons of doing this and how would i go about doing it?
Old Oct 22, 2010 | 05:53 AM
chaffe's Avatar
chaffe
Turbocharging Technician
It is the cheapest way of spinning both wheels for straight line traction and drifting, better than a ford lsd that will only transmit some power to the opposite wheel and cheaper than a plated or gripper diff. The downside is that when parking, turning tight corners slowly, the back wheels will skip about a bit. It can also be a bit livley when on a wet road, but then so can a gripper. You will have to take your diff out the casing to weld up the planet gears with a decent mig welder.
Old Oct 22, 2010 | 09:24 AM
andrewg's Avatar
andrewg
my escort was 4wd and had a locked diff was great fun on the track not sure i would like it on the road
http://www.youtube.com/watch?v=BZgc0b2IVfY
Old Oct 22, 2010 | 09:52 AM
DAN400's Avatar
DAN400
i ve welded god knows how many sierra diffs for stock cars,driftin etc and i ve never had to remove it from the casing! just drop the diff down by removing the diff mount, take the back plate off, clean out as much of the oil as possible, takes about 1 hour start to finish.
i would nt recommend it for a road car tho
Old Oct 22, 2010 | 09:59 AM
chaffe's Avatar
chaffe
if it was for a road car i would remove it to stop splatter and slag from getting into the diff and causing premature wear of the gears and bearings. Maybe ok for occasional use in a stock car, but for a road car i would be a bit cleaner about the job.
Old Oct 22, 2010 | 10:00 AM
XRT_si's Avatar
XRT_si
Bang on!
I've had a few cars with welded diffs on the road and they really are fine IMO. You only notice it at very low speed tight turns.
Old Oct 22, 2010 | 10:24 AM
lead_foot's Avatar
lead_foot
is awesome
My daily driver has a welded diff, only skips bait when parking. So much more controllable sideways compared to an open diff.
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
