Bucket Seats - how do you mount them on Ford runners?
I have a few Cobra bucket seats and also a spare set of drivers and passenger sierra cossie seat runners.
How do you mount them as the holes dont line up, etc.
the seats have holes in the bottom.
How have you guys mounted your seats in your sierras/fords?
I dont want to pay a hundred or so quid for mounts as thats more than what i paid for the seats
i did it by putting thk steel bars across the seat runners to line up with the bucket seat, bolt thesteel bar to the runners, then mount seat to steel plate. simple and cheap.
make sure you use the right size bolts etc tho, as you dont want them breaking in a crash etc.
i think i got pics somewhere of when i did mine. will try and dig them out
cool - get the pics up.
MY mate said he did the same thing but it made the seat very heavy which is not ideally what i want as the whole car has been stripped to save weight.
The alloy mounts are well expensive and even then i can only find the side mounting ones.
..BS Motorsport..
Ive just thrown my sparcos into my daily runner (206 hdi
) and the mounts weigh at least 4 times what the seat weighs!!! Didnt want to scrimp on material though and have them break. If they were going in my proper car Id probably bite the bullet and get some proper alloy ones.
Dont know if any of these might do the job ? http://www.demon-tweeks.co.uk/Perfor...ng_Frames/2012
In my MK1 i just welded each seat to a steel bar , and bolted the bar through the floor with big square washers either side , never going to pull through
mate the runner slide back an forth? there not for sale an i cant make any sorry. but i could trace around them an post it to you so you could knock some up yourself??? or check halfrauds
Carbon Crazy
RAn the problem you have is the bolt spacing on the cobras is different to the standard seats. Plates like that exist to rectify the problem. you could knock them up yourself quite easily.
You need to know the space between the runner holes, space between seat holes, forward and side to side and just make holes in the metal slat to suit.
These are the same as ive got fitted to my cobra seats i got mine from demon tweeks i cant remember how much they were but i think they were around the Ł30 mark.
shit, sorry for got to sort them pics out for you. ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
them pics above, are basicly what i made up.
if you can, bolt the runners into the car (the one they came from), just the runners. This will then give you the correct spacing so they can still slide back and forth.
now measure the gap across the runners. and get some metal cut to this length. then fix this to the runners.
heres a crappy pic i did quickly for you.lol the red bit is the metal you need to get cut.
![Name: seatrunners.jpg
Size: 11.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/134368d1501884623-bucket-seats-how-do-you-mount-them-on-ford-runners-seatrunners.jpg)
oh and mine where cobra clubman seats to.
Yes you bolt the plates to the seat then the seat to your original runner. I thought i had some pictures of mine when i put them in my car but i cant find them now but i found it best to have a trial fit as it were out of the car to make sure the sliders work properly. As the plates are a one size fits all type of jobby (hence all the differant holes) i needed to make a couple of spacers up to go inbetween the runners and the seat as my slider mechanism caught ever so slightly and stopped the seat from moving as free as i would of liked so its easier to do this out of the car obviously.
Cheers Mark.
Cheers Mark.
I took a seat base apart, taking the runners off the frame. I was thinking about mounting side mounts on the rails that mount to the floor.
![Name: IMG_3628.jpg
Size: 91.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/134376d1501884623-bucket-seats-how-do-you-mount-them-on-ford-runners-img_3628.jpg)
![Name: IMG_3635.jpg
Size: 92.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/134377d1501884623-bucket-seats-how-do-you-mount-them-on-ford-runners-img_3635.jpg)
![Name: IMG_3637.jpg
Size: 93.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/134378d1501884623-bucket-seats-how-do-you-mount-them-on-ford-runners-img_3637.jpg)
Realise that you're not using sidemounts but the principle is the same - rails off the base, attach mounts to the rails.
Charlie
Charlie
vdun01
Ford Fiesta
05-10-2017 08:14 AM
borboyous
22-08-2015 11:17 AM
saph in dorset
14-08-2015 10:10 AM
track.focus'd
12-08-2015 05:53 PM
