Custom Suspension Bushes for a Kit Car
Hi all,
I after some bottom arm bushes for a kit car I'm building and wondered if anyone knew where I could get some from?
Dave
Dave
DIY it's easy, if you have a lathe/access to a lathe, you can buy poly bar the diameter you want, put in freezer overnight, you'll then have around 15-20 minutes machine time on it, if you run out simply refreeze and start again.
What precisely do you both want ?, delrin can be used in some applications also.
Also try www.grommets.co.uk if you need a few. Only some sizes available in PU / neoprene from stock though.
RIB1122
12-08-2015 08:49 PM
track.focus'd
12-08-2015 05:53 PM
