Any electricians here....
garibaldi
need some advice on some wiring if anyone can help please ![](https://passionford.com/forum/images/smilies/roi.gif)
some twat other day ripped off the front outside light.
I have bought one today to replace it
However the wiring looks a tad odd. On the lamp unit you have the 3 standard wires, blue brown and green/yellow
the light outside can be switched on inside or can go off via the pir.
The wires from inside the house going outside are black, blue, brown and green/yellow
i have wired up the blue brown and green/yellow, but i don't know what the black one should be connected to??
Any ideas please
Any ideas please
Menace to society
One of the wires will be a permanent live I think. If the light used to go on and off when the switch inside the house was off, then that will be the case.
Best way of finding out is if you have a meter, connect it to the earth and the brown to see if brown is always live or just live when the switch is on. Repeat this for the black wire.
That should tell you which is which. The blue wire should have no real voltage on it relative to the earth.
If you don't have a meter, use a bulb to check the brown and black wires relative to earth but wear gloves.
All you need to then is tape off the permanent live.
garibaldi
The new light can only be operated by the PIR (as long as the switch in the house is set ON).
Put the spare perm live that comes from the house to the outside into a choc block and tape it up inside the new fitting.
garibaldi
here you go-this picture shows the wires (black, blue, brown, green/yellow)coming out of the house through black grommet and then the reattached block taken from old light unit showing the black cable to bottom right
![](http://i229.photobucket.com/albums/ee275/meandbex/rs-mania/69055_443718456775_518496775_5920150_2614778_n.jpg)
The next picture shows the factory fitted block and the wires coming out of the grommet attatched to the block ie brown to brown, blue to blue green/yellow to green/yellow
![](http://i229.photobucket.com/albums/ee275/meandbex/rs-mania/40879_443720126775_518496775_5920170_1437173_n.jpg)
Is the new lamp mains, and not Low volts or LED?
If so if the black from the house IS the permanent live, then it needs connecting to the Red wire which looks like it goes directly to the lamp, there looks to be enough wire to cut the red and stick both ends in the block where the black is.
Red should be the output from the PIR going up to the lamp
sit boo boo sit
brown - permanent live (if used means sensor in light wont ever be switched off and sensor is always active)
black - switch wire from switch,can be live supply when switch in house is down (will mean you can isolate light if you dont want it operate at anytime)
grey - neutral
green/yellow - earth
you can use either brown or black as your live supply just isolate unused conductor in a connector block inside the light
grey - neutral
garibaldi
grey - neutral
grey - neutral
After taking the light of this morning i dropped it and smashed the glass...
![](http://i229.photobucket.com/albums/ee275/meandbex/rs-mania/71541_444074056775_518496775_5925365_5186118_n.jpg)
If you want it working via the switch then black ( providing that is your SL ) into L, Blue into N and green/yellow into the earth ( symbol ) make sure the Brown in made safe ( bit of connector block with some tape on )
garibaldi
garibaldi
Thanks to everyone for their help- i really appreciate it, and i have it working kind off.....
1. I tried the brown to brown and left the black in a block and the light came on then went off but would not come back on either through pir or switch in hall way
2. I then tried the black to brown and then left the brown in a block. The light also came on and then went off but did not comeback on unless i used the switch for on or off, but then simply went off
3. I then did what cragrat recommended and cut the red wires-all is good as the light goes on and off via the pir. However if i turn the light on from the switch the light flickers then gets brighter.
So after sitting down and reflecting on what i have done i am assuming i have wired something wrong. I have the black wire coming out the house into the block which has a red wire in the same block together with the black linking to the pir.
The other red comes out of the block straight to the bulb. Would i be right in thinking that the black should go in the block on its own and then the 2 reds coming out the other side of the block together and then this would solve the issue of the light not being able to turn on and of via the switch??
garibaldi
the light did not come on via pir when tried the black to brown and then left the brown in a block.
Oh errr, you got worried now with them red wires
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
garibaldi
van_dogg_pavvy
03-03-2016 09:30 AM
geoffxr4
02-11-2006 09:00 AM
DaveEscos
11-02-2005 11:33 AM
