Cheap eBay Turbos!?
Turbocharging Technician
Cheap eBay Turbos!?
Any usefull information please!, i was wondering if anyone has had any recent experiences of the reasonably priced new turbos found on ebay? does anyone use one or know of thier capabilitys and thier longevity? i know in the past these turbos have had bad press but ive been told recently thier quality has improved. your thoughts please. i may add i am on about t3s and t34s, not t28s or the ko3s for VW/nissans.
competant bodger
i know of two people who say they are allright, i have one myself that i was given sat that i use as a paperweight in my workshop because i dont dare bolt it onto my cossie because just to look at it appears cheap and nasty. the bolt holes for the exhaust housing dont even line up with exhaust flange and the gaps around where the compressor housing fits on are not even equal all the way round!
things are cheap for a reason imo!
i see, im asking generically about the turbos for everyone it may interest. wether it is a t3 .48 exhaust or a t34 .68 or .70, with a .50 compressor housing, its the turbos im interested in not thier size or "spec". do you have any experience of them?
ive heard the one about the compressor wheels splitting, but never seen it? does sound like a couple of failures though, i wonder if they were running restrictors in the oil supply? ive had a few garrets been a bit oily, cured by a restrictor in the supply, a turbo doesnt need loads of oil to survive. intresting though, thanks.
In the VW world the KO3/KO3s Chinese turbos are reknown for shitting themselves at the earliest possibilty opportunity...
Theres a few horror stories out there
yeah mate think the cores are smaller on them and of a different design, more intrested in the t3 derived ones thanks.
i know what your saying, but its obviously the blowers im interested in, some of thiere stuff must be ok? my new i phone is made in china and it works just fine (when i get signal lol)
Is it worth mentioning that ALL modern TDI variable nozzle turbos are renowned for being shit, and can sometime last only 40-50k before going belly up.
in my experience of them, the quality is rock bottom, they dont last long, you will never stand a hope in hell of getting any form of warranty when they do go wrong, and they often do not perform as they should or have incorrect internals so off the shelf chips may not work.
the best option is to buy from a reputable dealer, who will give you a good quality unit that will work and last, face it you will end up buying one of these in the long term anyway, so it is much cheaper to do it now rather than later
yes my new iphone is assembled in China too, but we are talking a major company here with Apple not some small-medium sized company.
A very good friend of mine lost a few hundred thousand on a load of chinese motorbikes which were only fit for the scrapyard. Although the batches he received prior to and after that consignment were relatively trouble free.
Best of luck in your search
ive never ran more than 20 psi on any of my cars! all of them have been totally home brew creations admitedly, most ran about a bar. my pulsar was running 20 psi though. Did you not think the spring in the actuator was at fault? not the turbo.
cool, i bet that pulls well, a very expensive hobby tuning ybs though, so an expensive turbo is no problem. On budget builds often with near standard engines and relative boost levels i have found chinese turbos more than adequate on several occasions, one of wich has covered over 10k miles and is still going strong. all the bolt holes lined up with my garret elbow, and oil supply and return worked well. the engine and turbo produces no smoke and makes good power, my freind has also used two of these turbos on v6 golfs, both of which have worked well for thousands of miles. thanks for your input though.
why start a thread about these shitty turbos asking about them then say you have experience with them and answer your own question
because i wanted other peoples experiences not just my own, if i went in guns blazing saying i knew everything do you think anyone would answer. the truth is people who dont know anything are the first people to put thier backs up. its just a discussion about cheap turbos.
thats cool, turbos are relativly simple and cheap to produce, its just companys like garret like to add "modification" tax onto them, cos they can.
