ISCV question
Old Jan 20, 2005 | 11:05 PM
CraigN's Avatar
CraigN
Default ISCV question
recently my cossie has bee idlign well high aboout 1600
simon at secs gave me a few things to try which i have and whether the ISCV is plugged in or not it idels at same level
woudl this indicate it is stuck open and is fooked ?
Old Jan 20, 2005 | 11:13 PM
ECU Monitor Enthusiast
If you unplug the idle valve and it still idles high,
the valve is either stuck open or you have an air leak or the throttle is not
closing fully or the air bypass screw on the throttle body has fallen out.
Has to be one of the above !!!
Old Jan 20, 2005 | 11:50 PM
CraigN's Avatar
CraigN
i uplugged the iscv and nothing changed
ive just removed it how do u clean these things
the spring in mine moves fine up and down if i push it with a toothpick motion is smooth ting
will try a mates iscv 2morrow see if it makes any difference. i rebuilt my inlet when i reshelled car renewed all gaskets i have checked there all still tight and all the sensors and bits sticking out of the inlet are also
Old Jan 21, 2005 | 07:10 AM
St3V3_C's Avatar
St3V3_C
What about this bit Craig?
Old Jan 21, 2005 | 07:13 AM
It won't be the ISCV with rev's that high
more likely to be gasket missing from inlet or plenum.
Old Jan 21, 2005 | 07:17 AM
PhilM's Avatar
PhilM
PassionBMW.com Member
Ding, mine aint a cossie, but has a cossie iscv, and idles at 1800rpm easily with the iscv at only 40%
Old Jan 21, 2005 | 08:29 AM
CraigN's Avatar
CraigN
gaskets are all new only few thousand miles ago cant hear any air leaks
screw seems ok steve
Old Jan 21, 2005 | 08:45 AM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
should the car not stall when you disconnect the iscv?
Old Jan 21, 2005 | 08:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
not necessarily, not even if there is no other problem. the iscv is only there to raise the idle above a base speed when the engine is cold or has a load on it (plling away without throttle) or high electrical load.
when warmed up a little, and hopefully even when cold it should still idle without the iscv connected, albeit possibly at a low speed. if it doesn't, the throttle plate is closing too far or the air bypass is too small and the base idle needs setting up.
Old Jan 21, 2005 | 09:23 AM
CraigN's Avatar
CraigN
i wanted to get all these nigly little things sorted before igo see karl
gonna try a new iscv if it makes no difference see what he says
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
