helicoiling
Old Jul 27, 2010 | 09:25 PM
155lee's Avatar
155lee
Default helicoiling
hi,i have stripped the threads for 1 wheelnut on the hub flange on my rst.is it possible to helicoil this?would it be strong enough and be ok to have the bolt removed and put back in often?ta,lee
Old Jul 27, 2010 | 09:28 PM
wirralphil's Avatar
wirralphil
I'd say not tbh as the helicoil might come out when you remove the wheel bolt.
Can you not find another hub?
Old Jul 27, 2010 | 09:29 PM
studabear's Avatar
studabear
you could possibly re cut the thread to a more coarse thread, not sure on the helicoil, a second hand flange should be easy enough to obtain though
Old Jul 27, 2010 | 09:30 PM
steves24V's's Avatar
steves24V's
You wanna put a time sert in there if you know some one with a kit and the right size insert
http://cgi.ebay.co.uk/WURTH-TIME-SER...item2306858293
Old Jul 27, 2010 | 11:16 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
+1 time sert is a cracking kit. much more robust than a helicoil
Old Jul 27, 2010 | 11:19 PM
m4tt274's Avatar
m4tt274
just buy another hub, they are like 25 quid?
Old Jul 27, 2010 | 11:21 PM
wirralphil's Avatar
wirralphil
With using the Timesert kit the last 3 threads are tapers so when you take the wheel off 2/3 times it will be deemed useless.
Also as Matt said, a new hub is cheaper. Even with the new wheel bearing it will only cost the same as the Timesert kit.
Old Jul 27, 2010 | 11:33 PM
RSargie's Avatar
RSargie
i wouldnt worry to much you could helicoil it and it will be fine so long as the other 3 are all good. dont forget some cars come from factory with only 3 bolt wheels, so 3 bolts and a helicoil should be fine
Old Jul 27, 2010 | 11:39 PM
wirralphil's Avatar
wirralphil
Yes but the 3 bolts come designed like that
If you do decide to helicoil it use the locking nut on the helicoil one.
Old Jul 28, 2010 | 10:04 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
helicoil will be fine if it torques up ok but for the money and the time u may as well get a new hub and a helicoil that size will cost a bit too!
Old Jul 28, 2010 | 12:24 PM
155lee's Avatar
155lee
i thought it wouldnt be any use.as it happens i have pulled it apart and the flange is fooked,the bearings been run on the shaft so a new hub and bearing it is!
Old Jul 28, 2010 | 02:49 PM
SteveB's Avatar
SteveB
Years ago I drilled out and retapped and used "I think" some Audi wheel bolts that were 14mm...
Steve
Old Jul 28, 2010 | 03:21 PM
the mk1 kid's Avatar
the mk1 kid
Front or rear? As to me it would make a big difference!
That sad i'd sleep better knowing id sourced a s/h hub than doing any kind of repair...
Tom
the mk1 kid
17
Oct 6, 2011 02:36 PM
Pandauk
Jan 9, 2011 10:18 AM
Neil S
Jul 23, 2009 09:31 PM
PDH11R
Jan 8, 2007 06:53 AM
