Helicoil help
Old 22-07-2009 | 09:31 PM
Neil S's Avatar
Neil S
Default Helicoil help
I've had a minor setback with my car
Am in the middle of putting the head back on but one of the cam cap studs on the exhaust side has pulled out of the head.
I've had this happen before and helicoiled the stripped threads (I think I replaced 4 or 5 of them).
The problem is that the one that's pulled out is one I've already coiled
Can you get thicker helicoils? i.e. still M8 on the internal diameter but say 9mm external instead of 8.3mm?
I fucking hope so!
Cheers!
Neil.
Old 22-07-2009 | 09:43 PM
robrs2's Avatar
robrs2
Pop down to Teesside fastenings near the vauxhall garage preston industrial estate
Old 22-07-2009 | 09:44 PM
paul16v's Avatar
paul16v
Monte 087
Neil you could use a time-sert insert but i think they are quite expensive for the kits and you only need 1 hole doing or drill out to say M10 if space allows and plug the hole with a bolt & re-tap it.
Old 22-07-2009 | 09:56 PM
Neil S's Avatar
Neil S
Yeah I get on quite well with the lad there, will go and have a chat with him tomorrow Rob
I'm off to look at these timesert doofers now, cheers Paul!
Old 23-07-2009 | 07:17 AM
Neil S's Avatar
Neil S
They look promising but I can't find any UK suppliers. Anyone have any idea where to buy or hire timesert kits?
Old 23-07-2009 | 07:25 AM
NEEDFORSPEED's Avatar
NEEDFORSPEED
agreed timeserts are unreal. good enough for headbolt threads! you can get them from wurth but will cost you around 180 for the kit
Old 23-07-2009 | 10:31 PM
Neil S's Avatar
Neil S
Sorted now, as luck would have it, the spiral I pulled out of the hole last night was just the ally thread. I thought it was a helicoil as it came out in one lump!
Stuck a helicoil in there and it's fine now
Neil.
the mk1 kid
17
06-10-2011 03:36 PM
Pandauk
09-01-2011 11:18 AM
155lee
12
28-07-2010 04:21 PM
PDH11R
08-01-2007 07:53 AM
Quick Reply: Helicoil help
