Need some secs advice
Re instaling my secs monitor and have managed to pull
the grey wire out the back of the plug i think it runs the water inj
WHERE does it go there is 2 places on the plug but which one
HELP
HELP
Ok, the water injection is on the 4 way connector that is directly beside the
8 way connector at the bottom of the board on the left hand side
looking from the back.
On the 4 way connector, the pin nearest the corner (pin4) is the negative trigger
output for water injection.
Pin 2 on the same connector is the +12 supply OUTPUT (if required)
http://freebies.about.com/cs/allaboutfreebies/qt/freesex.htm
P.s. you spelt it wrong
The grey wire supplied on monitors that had the rev counter facility
was the rev pickup from the ecu.
IF this is the wire (colour is NO guarantee unless I fitted it)
it will come from ecu pin 25.
CHECK THIS BEFORE - RECONNECTING IT.
This connects to pin 5 of the 8 way connector.
Pin 1 being on the right hand side.
Chasing Radders
Originally Posted by TIFF-C20WTH
I thought grey is RPM
mk3ste
17-10-2021 10:09 AM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
