cossie dump valve help
had my car on the rollers today and mentioned to the operator it was really sore on juice.he told me my dump valve wasnt helping as it was hissing and suggested removing it and changing it for a recurulating version if i still wanted to keep one.pretended i knew exactly what he was on about but now im home,i dont.im going to take it off tonight as im going up to knockhill tommorow and im curious to see if the petrols any better without it...anybody help.(small turbo escort cosworth)was a big forge valve with loads of woooooosh
it sounds like he is saying your dump valve is leaking, therefore giving you a boost leak, which in turn is giving you less power meaning you are pressing the throttle harder in order to go at the same speed. a re-circ dump valve will make no differance, you just need one that doesnt leak, or dont run one
competant bodger
why pretend you knew what he was saying? you should have just asked him to explain it to you better its not like he is going to take the piss out of you for not knowing, the whole point of getting your car tested is to recieve sound advice about anything that needs doing!
of course you can run aftermarket dump valves on small turbos!!! or big turbos
ive a baileys on mine 80 k and never had any issues .
where do you get your information from?
petrol consumption with or without a dump valve ,if you think there is a difference your wrong-can i assume you havnt got an escort cosworth reading your opinions.
that sounds along the line as what he was telling me but prior to it dumping,its leaking/partially open and hence is putting more fuel into it than it requires,as it was spluttering as he held the revs around 2k if that makes anymore sense.it was ava in glasgow incidently.valve now removed and no woosh or chatter so will see if the fuels any better on the run tomorrow.cheers for your posts
that sounds along the line as what he was telling me but prior to it dumping,its leaking/partially open and hence is putting more fuel into it than it requires,as it was spluttering as he held the revs around 2k if that makes anymore sense.it was ava in glasgow incidently.valve now removed and now woosh or chatter so will see if the fuels any better on the run tomorrow.cheers for your posts
Recirculating dump valve is the better option NO whoooosh
When driving
Russ Payne
25-09-2015 08:29 PM
