problem fuel regulator on cossy cap
on my 2wd cossy just near the fuel rail for the injecters is the fuel reg ,on the top of it a presume theres a cap missing if i put my finger over it you can feel it sucking is ths normal.also on the turbo side the manifold that bolts to the engine the bolts were loose.
Hmm, this is where your problems arise.
The fact the reg was tampered with suggests you may be running non standard fuel pressure. If thats the case, running standard pressure with a nice new reg is going to leave your fueling either rich or lean, and theres no way to find out bar testing it.
saying that i have noticed the cars lumpy when cold on a morning also the back box of the inside of exhaust is realy black.it was mapped by powerstation but that was a while ago,
It's so miniscule, I didn't bother doing anything with mine, was mapped like that perfectly too, if I plugged the hole now the change would be too small to detect.
The std pressure eg has TWO diaphragms inside, both connected in thier respective centres to the pintle(valve), amazing what can be charged for such a simple to make device.
It could fail a fraction more and lean of the AFR without you knowing until you have molten alloy in the sump !
A small leak at idle giving a small effect has a larger effect on boost as the regulator is a multiplier device.
You always seemed switched on to me which makes it even more surprising that you think its ok to run the car like this !
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Lets not forget, it is a piece of precision engineering that is tested and calibrated.
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
