Compression Ratio question..... Cosworth
Old 01-06-2010, 09:23 PM
BigErn
BigErn's Avatar
Default Compression Ratio question..... Cosworth
One for the folks who know how to do the relevant calculations.....
Just been chucking ideas about today and talking about stuff we have worked on in the past and one car cropped up that had 3.3mm skimmed from the top of the piston to lower the comp and was still boosting over 30 psi and 8k rpm with no problems for years.
That led to the question of doing the same to a standard Cossie piston, what would it drop the comp to??
Old 01-06-2010, 09:30 PM
wozzy
wozzy's Avatar
Old 01-06-2010, 09:38 PM
BigErn
BigErn's Avatar
Thanks for that, very helpful.....
Old 02-06-2010, 05:12 AM
2001ode
2001ode's Avatar
Hi,
I have result.
If you cut 1 mm. on the top of piston, CR down from 8 to 7,4.
If you cut 3 mm. around the top, CR down from 8 to 7,2.
Pic is 2wd piston.
Regards.
Claude
Old 02-06-2010, 08:34 AM
BigErn
BigErn's Avatar
Thanks Claude... top man
Old 02-06-2010, 08:52 AM
lawnsy
lawnsy's Avatar
So would this be about the same comp ratio if this was done to a 4x4 piston...?
Old 02-06-2010, 09:26 AM
2001ode
2001ode's Avatar
No because 4 wd combustion chamber in piston is different (smallest than 2wd piston)
and CR will be a little bit small, I think.
Regards.
Claude
Old 02-06-2010, 09:30 AM
lawnsy
lawnsy's Avatar
I only ask cause i have 4x4 pistons in my engine with 3.3mm skimed off the top and always wondered on the cr....
Old 02-06-2010, 09:33 AM
JamesH
JamesH's Avatar
Why does it matter? My new engine will be boosting way in excess of 30psi and rev to 7800rpm with a compression ratio of 8:1
you don't need to drop the compression loads to run high boost!
Old 02-06-2010, 09:38 AM
lawnsy
lawnsy's Avatar
Because the bottom end is like this now, It has run 36psi for the last 2 years and is still in good condition but now i have a T4 to go on and was sitting wondering what sort of cr it was..
Y waste money on new pistons if it does not need them......was told when i bought the bottom end that the cr was around 6/9-1....
Old 02-06-2010, 09:56 AM
J1mbo
B1mbo
J1mbo's Avatar
before having guesses at it,. you need to know how much the std piston sticks out of the top of the block
if the block has been skimmed alot, then taking 3mm off will not effect it as greatly as you may think
it needs to be measured properly so the mapper knows what he is dealing with, a guess isnt good enough imho
Old 02-06-2010, 09:59 AM
BigErn
BigErn's Avatar
Good point Jimbo. I know my block has had a skim and the pistons used to stick out by a fannys hair where as my spare block the pistons used to sit dead flush.
Chip
*** Sierra RS Custard ***
Chip's Avatar
You dont want to end up with the outside edges of the piston being too far from the head at the top of the cycle, this squish region is important.
I always aim to have them outer edges of the piston protruding into the headgasket slightly (.1 -.2 mm typically)
So ideally you want to take material out of the centre to lower the CR not from the edges, but as per the excellent picture above, there is only a finite amount you can take off of course!
Old 02-06-2010, 10:13 AM
lawnsy
lawnsy's Avatar
Mmmm my pistons on top dead center are about 4-5mm off the top of the block.....
Old 02-06-2010, 10:16 AM
lawnsy
lawnsy's Avatar
Old 02-06-2010, 10:20 AM
Chip
Chip's Avatar
FAR from ideal!
Old 02-06-2010, 10:27 AM
lawnsy
lawnsy's Avatar
Can you explane a little bit more for me why this is the case please...
Old 02-06-2010, 10:31 AM
B13 JUS
B13 JUS's Avatar
alright mate, its justin who was speaking to you at the weekend.
is this the engine you are building for over 500bhp?
Old 02-06-2010, 10:32 AM
lawnsy
lawnsy's Avatar
Yip...
Old 02-06-2010, 10:38 AM
Gary F
Gary F's Avatar
I'll be flying about in my space ship before Lawnsy starts on his engine
Old 02-06-2010, 10:45 AM
lawnsy
lawnsy's Avatar
Love you to gary....Now get the escort booked on track on sunday and stop been a puff....
Old 02-06-2010, 11:05 AM
Chip
Chip's Avatar
Because you will make less power like that.
a proper squish band massively increases the amount of turbulance that the mixture sees, which makes it burn a lot better, especially at high rpm, so without it working properly you will lose power.
The prescense of much gas in the squish region can also increase the risk of detonation, which means you have to run less timing to avoid det, which means less power as well.
It will basically make your engine more inefficient and sluggish if you lose this part of the piston.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: Compression Ratio question..... Cosworth
