97 mondeo starting problem
Old May 24, 2010 | 05:53 AM
m nicol's Avatar
m nicol
Default 97 mondeo starting problem
I have a 97 ford mondeo 2.0. I have converted it to manual, run car with automatic computer and wiring loom by setting shift selecter to park, to allow car to start. Car wood not run properly. Was told by ford garage needed to swap computer and loom to the manual ones. Have done that now car wont start. They have tryed to re program keys but need to locate the pats system and change that over also. Does anyone no were this is located and if this will work? Or is there another way to get around it and start the car?
Old May 24, 2010 | 06:27 AM
rich123's Avatar
rich123
97 mondeo why have you gone to all that hassel u can pick 1 up cheap as chips i have a 98 mondeo si with st kit be selling that soon 300 quid 12 months mot
Old May 24, 2010 | 07:11 AM
focusjames's Avatar
focusjames
life is good
you have pm
Old May 24, 2010 | 08:29 AM
m nicol's Avatar
m nicol
wats pm?
Old May 24, 2010 | 08:34 PM
pm = personal message
You do indeed need a manual ecu, as the auto ecu will limit revs to 4000 if in park or neutral, the pats on yours should be located under the ash tray/lower dash area bolted on top of the trans tunnel.
Old May 24, 2010 | 09:01 PM
m nicol's Avatar
m nicol
thank you ill have a look see wat i can find wat exactly does it look like?
Old May 24, 2010 | 09:27 PM
m nicol's Avatar
m nicol
also as i have the hole car the manual came out of will the pats be in same place on this thanks
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
The Enigma
13
Aug 20, 2015 09:38 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
