what happens if i remove lambda sensor ?
Old May 13, 2010 | 10:26 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default what happens if i remove lambda sensor ?
ok random question
i recently changed my exhaust with decat and it didnt have bits for the lambda so i just left them off,,,,, car ran fine ( well as it used to)
now i have just changed gearbox,,,, i had to disconect the battery for it and now when i start the car it runs for a few seconds,,,,,, the just dies and if i tickle the throttle it cuts out quicker
wondering if i need to reconect up the lamdas or not or could it be another issue i have ???
take into account that it did run before with the lambda sensors in the boot but i never disconnected the battery when i changed the exhaust hence me asking
Old May 13, 2010 | 10:29 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
the world will end...................boom
Old May 13, 2010 | 10:33 PM
Ginge !'s Avatar
Ginge !
btw this is for a subaru impreza
Old May 13, 2010 | 10:35 PM
pete mcrash
...in that case u'll get a blow job and ur car will be fine.....pmsl
Old May 13, 2010 | 10:37 PM
fraser9764's Avatar
fraser9764
i would say you have another problem, but you need to get your lambda refitted too!
Old May 13, 2010 | 10:43 PM
Ginge !'s Avatar
Ginge !
lambda sensor wont fit and the diagnostic one is stuck in the old cat
Old May 13, 2010 | 10:51 PM
botters's Avatar
botters
competant bodger
without the lambda your fuelling will always be incorrect and you risk running lean enough to melt the pistons or rich enough to cause bore wash, take the exhaust to someone like longlife or powerflow they should be able to weld a lambda boss into your exhaust so that you can refit it, having it disconnected will not cause your car to not run, i would say you have disturbed something whilst removing the gearbox or battery check all your connections are on plus make sure you have fitted your earth lead back on the box if it had one fitted
Old May 13, 2010 | 10:53 PM
Ginge !'s Avatar
Ginge !
im gonna check all that, im just thinking of ideas at the min to save me back tracking
i just tried to start it tonight in the dark, im gonna add fuel, change the fuel filter and plugs and give it another go, just wanting ideas where to look if that makes sense
Old May 13, 2010 | 11:04 PM
SiZT's Avatar
SiZT
Wrong
Edit: Just realised I left this on a cliff hanger! Just take your downpipe, decat section w/e to a local exhaust place and they should be able to weld in a new bung for you. You can run your car without an o2 sensor (afterall this is what happens when it is being mapped). But for decent fuel economy (helpfull when driving to Germany you could do with it). I can't see why it would stop the car from starting though as you would be running open loop on cold-starts.
Old May 13, 2010 | 11:46 PM
botters's Avatar
botters
competant bodger
[quote=SiZT;4901858]Wrong
no i aint mate while i have not a massive amount of experience with subaru's i have seen lamda failures cause melted pistons (and cats for that matter) on things like corsa's clio's and other badly made cars
Old May 14, 2010 | 09:53 AM
Jim Galbally's Avatar
Jim Galbally
botters,a narrowband lambda sensor is only used for cruise and idle conditions, it is completely ignored on load, so a faild lambda will not affect fueling under load (ie piston melting) conditions, just make the car run like a bag of shit
Old May 14, 2010 | 06:09 PM
Ginge !'s Avatar
Ginge !
cool, the closed loop dont work on it as its got a "mines" chipped ecu, i dont even get a check engine light on,,,,,,, that includes when i had a hole the size of a apple in the cat !!!!
now lets think of other things,,,,, oh and jim time table and nearest station to bromley as its been a while pmsl
Old May 14, 2010 | 06:57 PM
RC4's Avatar
RC4
shouldnt you be asking on scoobynet or something ginge???
pmsl
pmsl
pmsl
Old May 14, 2010 | 07:33 PM
wayne dowling's Avatar
wayne dowling
Hi there should be a green multiplug on the bulkhead make sure thats pluged in as its for the engine manegment iirc
Old May 14, 2010 | 07:42 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats right, and it only adjusts the fuelling by a really small amount (IIRC around 5%) so can in no way cause starting or melting piston issues.
Old May 14, 2010 | 07:45 PM
Ginge !'s Avatar
Ginge !
ok i checked everything, turns out i forgot to connect the maf sensor hose up to the inlet on the turbo,,,,, so the maf wasnt reading vacum i guess
connected back up and POOF its working again
cheers for your help guys :cheers:
and RC4, i did post on scooby net,,, i do it all the time but this site seems to answer and give me correct answers aswell with my clutch issue
it looks like i will be going to the ring,,,, downside it means i wont be borrowing vans and cars from work,,,, so back to 60 quid a week fuel bill
guess it wont be fixed for a few more days
Old May 15, 2010 | 09:40 AM
Jim Galbally
thats a pretty big hose to forgot to put on
Old May 15, 2010 | 09:52 AM
st3v3's Avatar
st3v3
as said,if i remember correctly its about 2000rpm where it stops using the lambda
Old May 15, 2010 | 01:40 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I thought it was 4500rpm
lambda works for idle, part throtle and switches off at 4500 or full throtle.
Thats what I got told anyway!
Old May 15, 2010 | 04:07 PM
st3v3's Avatar
st3v3
Have checked my info and its about the 3200rpm mark.
Although, as said will be needed for good idle mixture to keep smoothness and more than likely for the MOT emissions test,as this is done at idle.
Old May 15, 2010 | 04:43 PM
Ginge !'s Avatar
Ginge !
it wasnt taken off it had pulled off when we jacked up the engine to tilt it and get the gearbox at a angle to get it on, never touched it hence i never checked it its only cause i was looking at plugs on sensors i noticed it
Old May 15, 2010 | 08:38 PM
stevieturbo's Avatar
stevieturbo
C**t
[QUOTE=botters;4901896]
Originally Posted by SiZT
Wrong
You are totally Wrong, with a capital W in fact, because the lambda sensor has fuck all to do with WOT operation.
But it must be a really cheap shit exhaust if it doesnt have a spot for teh lambda sensor to screw into.
Without the sensor, the car will just be very hard on fuel.
DixieTheKid
11
Jun 6, 2020 11:20 AM
Fudgey
Sep 17, 2015 01:06 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
