CVH Turbo fan switch wiring HELP
Is there a short section of loom that runs from a round black plug around the cross member area up to the thermostat housing switch? Ive just put my engine and loom in and i dont have the blue plug for the switch. I do have 2 similar looking round black plugs one at each end of the cross member. I presume one is the fan wiring plug but not sure about the other? Just wondering if there is a short section that lpugs into this and then the fan switch??
CheeRS for any help.
..BS Motorsport..
theres no seperate parts to s2 loom, theres main engine loom then battery-starter & alternator loom. Has somebody chopped it about and installed a manual switch perhaps?
..BS Motorsport..
put some pics up, most parts of the loom just fall in to place and most of the connectors are unique so we should be able to identify it for you, wire colours will help too.
the fan wiring comes out of the loom by the horn and passenger side lighting into a black sleaving up to the blue plug, the 2 wires you are looking for are solid black and black/red both are quite thick
Matt Baxter
16-09-2015 08:30 PM
