Twin Scroll vs Single Scroll turbo setup.
Old May 13, 2010 | 03:22 PM
lead_foot's Avatar
lead_foot
is awesome
Default Twin Scroll vs Single Scroll turbo setup.
Intresting information.
From a Mazda SAE 20 years ago.
and GT4094R twin scroll vs single on Honda S2000:
http://forums.evolutionm.net/evo-eng...ore-after.html
Any one else got any experience of using twin scroll setup?
Old May 13, 2010 | 03:47 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Certainly deomonstrates it well on those graphs.
I know sheady saw a big difference years ago when he swapped to them as I spoke to him about it at the time, in fact I dont think he ever uses a single scroll now.
Old May 13, 2010 | 04:27 PM
Oranoco's Avatar
Oranoco
Can somebody explain twin scroll and single scroll differences? Not something I've dealt with but always willing to learn
Old May 13, 2010 | 04:50 PM
lead_foot's Avatar
lead_foot
is awesome
Here you can see how a divided or twin-scroll turbocharger has two separate exhaust gas entry paths into and through the turbine, maintaining the improved scavenging effect and exhaust gas flow achieved by pairing complementary exhaust primaries on the header.
Two finely crafted, equal-length manifolds from Full-Race, where the divided flange fed by paired primaries clearly differentiates the twin-scroll design (left) from the single-scroll design (right).
Old May 13, 2010 | 05:53 PM
Oranoco's Avatar
Oranoco
Ahhhh. Quite simple really, glad I asked now
Old May 13, 2010 | 08:17 PM
Fagin's Avatar
Fagin
Twin scroll can be effective for quicker spool and better torque. The Subaru's have been using it for years on the JDM models. Mine was originally twinscroll, but this hampered it if you wanted a lot more power using stock housings, as this is ultimately the limiting factor. Move to a conventional garrett fitment and rotation, and the world is much more your oyster.
However, already achieving over 600ftlb of torque and 1bar at circa 2800rpm on a single scroll 3076, I doubt I need to worry too much about spool or throttle response to warrant even looking at twinscroll. The next build maybe a different story!
Old May 13, 2010 | 08:21 PM
Mark Shead's Avatar
Mark Shead
Going from a Single scroll to a twin scroll GT35 housing I picked up 400rpm earlier spool with this manifold.
Mark
Old May 13, 2010 | 09:02 PM
lead_foot's Avatar
lead_foot
is awesome
Mark
Why not use the standard 2WD cossie manifold? Or would it of caused a restriction at the power your aiming for?
Old May 13, 2010 | 09:05 PM
Mark Shead's Avatar
Mark Shead
1 the power the other is making the 2wd one work with the correct type internal or external wastegate.
Mark
Old May 13, 2010 | 09:24 PM
lead_foot's Avatar
lead_foot
is awesome
Mark
Fair enough, Twin Scrolls are the way forward then?
Old May 13, 2010 | 09:28 PM
Mark Shead's Avatar
Mark Shead
100% Yes its the way forward.
Mark
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
kevin36
Sep 2, 2015 06:24 PM
