renault imobiliser problems
Old Jan 14, 2005 | 02:59 PM
apples24's Avatar
apples24
Default renault imobiliser problems
the good old comon renault imob problems, i believe extremely common, have a 1995 espace thats turnsand fires but dies instantly, normally its cause the immob has cut in, so ya press the keyfob to lock and unlock the doors .... restart and the car runs
but this fooker doesnt
i presume its a cut off to the fuel pump? anyone know how to disable / bypass?
Old Jan 14, 2005 | 04:06 PM
apples24's Avatar
apples24
heeeeeeeelp
Old Jan 14, 2005 | 04:48 PM
TrickyDicky's Avatar
TrickyDicky
if i remember correctly the immobiliser unit is the item that plays up, it cuts fuel supply via ecu.
not sure about wiring round it to be honest, maybe best to try aned source 2nd hand immob unit and a key fob-the metal key blade off your old key screws to it to make it look original.
hth
Tricky
Old Jan 14, 2005 | 05:09 PM
apples24's Avatar
apples24
if cuts fuel supply cant i re - live the pump?
Old Jan 15, 2005 | 07:54 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Check the end of ya indicator stalk. On the old clios, there is a button so that you can disable the factory immobiliser. Have a look in the handbook..if there is, it will tell you in there & how to input the code. You will have to speak nicely to the Renault goons tho for them to give you the code in the first place.
Old Jan 15, 2005 | 08:41 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
I thought that 99% of the time renaults were immobilised due to the engines being fooked?? (yes, I have had a 19 16v, never again what a shite car, french cars are poo )
Try dudley renault spares, not got the number to hand but speak to dean or lee, they are shit hot on them and dead helpful
Old Jan 15, 2005 | 09:11 AM
apples24's Avatar
apples24
hmmn but surely theres a way to bypass, ive heard the ariel in the roof can leak water onto the circuit directly below that houses the remote sensor
Old Jan 15, 2005 | 02:29 PM
TrickyDicky
if the central locking is working off fob though that isnt the problem.
i suppose its feasible to re wire the live to fuel pump to an ignition switched live.
hth
Tricky
Old Jan 15, 2005 | 02:31 PM
apples24's Avatar
apples24
thats what i was thinking, although im unsure as to weather it is actually the pump it cuts out, having a nightmare searching the net to find out what it actually imobilises
Old Jan 15, 2005 | 02:55 PM
TrickyDicky
it is the pump it immobilises, thats why the engine starts on cranking but once you release key thinking its started the pump stops and fuel pressure drops hence it stalls after a secondish.
i'm sure it doesnt cut spark as well, only thing you can try is live wire the pump first see if it runs.
Tricky
Old Jan 15, 2005 | 02:58 PM
apples24's Avatar
apples24
ahh that makes sence then as due to me hearing the pump prime i was assuing wsnt that but if it cuts it once fired thats all good
thanks mate ill give that a go
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
