Why dont petrol tanks explode?
RWD Racer
If you have an internal fuel pump?
Why is it the tank doesn't explode?
I assume the motors still create a spark?
If the tank is low to empty, why don't they explode ?
RWD Racer
But can't see me wanting to try it !
Whereas a elecy pump would have a constant spark, like a spark plug
A petrol tank DOES have air in, as it is not a sealed unit, it has a breather otherwise it would collapse inwards due to vacuum!
A petrol tank has a breather but it's not an 'open' valve, otherwise all ya petrol would disappear in vapour!
The oxygen content is too low to allow the petrol to ignite.
st170 breaking
burn his legs bad but his cock wasnt singed
..BS Motorsport..
was a good mythbusters where they kept shooting a petrol tank to try get it to blow up like they do in the movies, took them ages and they had to use tracer bullets in the end to eventually get it to go. Seems to be a lot harded than youd imagine getting petrol to go up!!!
Boost Builder
ill never forget my mate dropping his fag in jerry can and me running for my life...
Ill also never forget me pumping fuel out of an old escort with a fuel pump and the whole side of the car going up, my pants too, Running to the garage in my boxers looking for the fire extinguisher whilst my pants are on fire, the car and the pump STILL pumping fuel onto the jerry can, lesson learnt!!
neeeeeeeeooowmmmm
Ban[B][/B]ned
Benni.
Your right, but the valve opens as the fuel is being drawn from the tank - hence air entering the tank - when the pump is running!
I guess so Benni as its full of vapours! Thats why it costs a fortune when old petrol stations are sold for building on as the tanks have to be decommisioned - imagine the vapours in those!
PassionFORD Member
Try having a jar that has just been emptied of petrol and drop a match in it. More than likely you will get a flash or a little fire.
Resident Wrestling Legend
you are all lier's!!!!
the movies are real!!!!!!!!!!!
fuel explodes, just look at all them films where they blow up the fuel depots and stuff so that the baddies can't escape, with explosions and exploding shit, and bulliets and stuff
stop filling benni's head with usefull facts
neeeeeeeeooowmmmm
I'm with you Dojj, and you can add Nitrous Oxide to the list, just like in the F&F film where the cigar lighter ignites the nitrous vapour!
Pure artistic license, or to put it plainly, bullshit
Diesel tanks needs to Be flooded with C02 as well .. Same with Hydraulic and other Oil tanks ..
I've see a Diesel tank being welded still on the truck full of fuel .. You just gotta weld below the fuel level line ..
Ban[B][/B]ned
Benni.
this is a fuel tank imploding
http://www.liveleak.com/view?i=8b8_1208931048
Wonder why they did the test? MM maybe a pressure test incase it goes underwater?
Yeah... Must be crazy. So can I go and throw a lit ciggy' on the floor at my local garage while shouting 'I'll do it, I'm gonna' end it!' And everyone will panick for nothing? Could be a good April fools this... My local might start turning the pump on at request now.
Benni.
Benni.
