Why dont petrol tanks explode?
Old 25-03-2010, 07:55 AM
  #41
foreigneRS
Testing the future
foreigneRS's Avatar
Originally Posted by zetec-Sam
Diesel has to be compressed to explode
wrong. in simple terms it needs to be hot to combust
i suspect that you are getting confused by the term 'compression ignition' engine, but that just means that the compression process increases the temperature of the diesel/air mix until it ignites, but it's the temperature that does it, not the pressure.
Old 25-03-2010, 09:11 AM
  #42
Chip
*** Sierra RS Custard ***
Chip's Avatar
You need a suffiecient quantity of each of: fuel, heat, and oxygen
in order to get a burn
in a petrol pump you are missing enough heat and enough oyxygen
Old 25-03-2010, 11:06 PM
  #43
James
James's Avatar
Originally Posted by Lee Reynolds
Your right, but the valve opens as the fuel is being drawn from the tank - hence air entering the tank - when the pump is running!
is this why you shouldn't fill up with the engine running? - i do this all the time, am i an explosion waiting to happen!?
Old 25-03-2010, 11:19 PM
  #44
Chip
Chip's Avatar
should think its lots of reasons all at once like because there is more chance of your car catching fire when the engine is running than when its not, and if it catches fire you dont want to be pouring petrol into it.
also it could jump into gear accidently if you have a child or pet in the car and they knock the lever and make it drive off and rip the pump line out the pump
etc etc
just generally speaking something is more likely to go wrong with the engine running than not
Old 25-03-2010, 11:26 PM
  #45
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
I never saw the point in running the engine, you're just burning fuel unnecessarily as you're putting it in
Old 25-03-2010, 11:44 PM
  #46
cjwood555
cjwood555's Avatar
I would guess that in-tank pumps are brushless too and therefore don't arc...
Old 26-03-2010, 08:24 PM
  #47
James
James's Avatar
see i think of it don't see the point in increasing wear on the starter motor switching off then back on five mins later
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
mpilk
27-09-2015 09:21 AM
Quick Reply: Why dont petrol tanks explode?
