spark plugs question
my cossy stage 3 runnig rich. my plugs are black dry so its runnig rich and every 4 weeks i have to change plug iam using champion 59 plugs and it will hold back if i dont change plug every 4 weeks could i turn down the co with out altering the set up off the engine
thanks people
i have to change my plugs every 4000 miles never mind 4 weeks
what kind of mileage are you dooing in those four weeks?
what colour should they be if your car is perfect?
thanks people
my cossie ran really rich and it turned out to be the connection to my 3 bar...got it rewired and it was sorted.
my plugs are brown/grey so mine must be running ok
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
my car runs good so that would mean the conections on the map sensor is ok or am i wrong and stu ive changed all sensors and had the car set up and it was perfect and then i changed my head gasket and this starts running rich
Then I'd say you need to get your car set up.
On a very similar spec, I wouldn't use too much fuel at all on greens, and changed the plugs every 2000 miles because I wanted to, and not because I had to.
chowfornow
14
05-01-2019 09:01 PM
wheelwizardrefurbs
24-09-2015 08:35 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
