How do u cancel bids or end auction early on EBAY??
Dude im on that screen now but i can only see the option for End auction early!
I would like to cancel the bids that this twat has made on an item!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4518067968
You can clearly see that it says DO NOT BID
Be carfull jano as if someone bids in the last 12 hours you can not cancle the bids or end the auction! So may be best to end it when there is like 1 day left to go
nah you can cancel your auction with 30 minutes to go if you want.
you cannot withdraw a bid you made in the last 12 hours.
as per rscat who is correct
Jano, you should have put the minimum bid amount in as £4,000 instead of £0.01p then that way you would have no problems
Ill see if i can find the link to end auctions
Hit the `Site Map` tab at the top, youll see `end auction early` listed down the page somewhere, think its in the middle column
The 'End Auction' option is there if you go to My Ebay, find the item you're selling, and click on the little arrow on the right hand-side next to it.
Dr. Ickxs
15-09-2015 10:15 PM
