most power out of a std rst head?
with a 285t2 cam in it,whats the most i could (realistically,not gonna wind boost to 90 psi!!!) get with std valves etc....... im a cheapskate,not spending shit loads of cash,learnt the hard way with the cossie,gonna have a 1.8 zetec bottom end hopefully,any ideas?
sorry christian,i know,but couldnt remember and thought id ask while im sorting my engine stuff out on here. so 250?sweet,sounds good enough for a quick car
#1 in Spelling Club
There are certain benefits to retaining the standard head, such as low down punch. Mine lost some of its low/mid range when I swapped to a Stage 3 head. I wouldn't go back to it as I have gained in the Top End stuff, but I would stick with a Standard head if you want 220ish bhp.
I wont lie, 250bhp is unusual for a Standard Head.
so with a zvh and std head t2 cam i should have a quick car with minimal lag?good good.tbh 250 would be great!but...i aint a dreamer,i wont be runnin 2 bar! itll be 15 - 20psi i reckon. but i dont want to have to repair the damn thing EVER unless i want to!
just finding my feet
greg loose the cam mate if ya gonna keep a standard head as the t2 cam is a top end power cam and ya gonna create lag and lose the power band with out it tbh
get a new standard cam and then get 220 low lag engine
ported heads are only a benifit if ya have more air to flow thrugh it otherwise ya lose power
gadget got 250bhp from a standard head and a cam BUT he was runnign more boost
zetecs dont rev enough( in standard form) top benifit the t2 cam shaft mate
good luck though
good luck though
Didnt think 220 would be possble on std head....and i nearly changed it Glad ive stuck to std now....i only want 200.
What boost will i need to run on std compression to reach 200?
Originally Posted by MarK4
Agree with andy 17-19 depending on condition of engine
Hmm, so if i run 15 psi thru the big GRS, ill get no ignition retard as acts will be low, so will i see about 185-190 at that then?
rad,unlike you i dont really care whats under the bonnet as long as its quick,cheap and reliable!zvh seems the best way,my whole car will probably cost less than a fancy 1.6 monster bottom ended efi thing that u want,and if it breaks ill find another 50 quid engine and transfer the bits!
Unknown.
I challenge anyone to get a proper 250 on a std head on a T3. Christinas made around 220 odd with about 25psi. As a comparison, Dave E's old car made exactly the same power, on the same day, with only 13.5 psi, using a big valve head. My car made 210bhp on a std head on 17psi. I could have had 220bhp with around 20psi. Worth noting though, that these were all very well sorted cars.
with forced induction its going in there weather the head wants it 2 or not so i can see a s standard head restricting the power that much
JK12
33
26-04-2021 12:09 PM
