ka heating problem
Old Feb 25, 2010 | 05:00 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
Default ka heating problem
my girls ka has a heating problem ive put a new thermostat and housing on temp sensor and heater control valuve and its still blowing cold air throgh the dash on full speed .. only thing ive noticed is one side of the rad is hot the other side is cold have i bleed this right or have i missed some thing out please help long drive tomo ,
Old Feb 25, 2010 | 05:03 PM
RichieST's Avatar
RichieST
Could be an air lock? Unsure if these have a bleed nipple or not. Try running the engine, take the rad cap off and pump the hoses with your hand to try and get any air shifted.
When you turn the heater control does the cable on the heater valve move? In case the cable has snapped?
Old Feb 25, 2010 | 05:08 PM
SiZT's Avatar
SiZT
Near the bulk head theres a little control box with 2 pipes going into it and 2 pipes coming out. It'll be that I'm almost sure, common problem and all that.
Old Feb 25, 2010 | 05:19 PM
benjaminsarmy
yes i have changed this today Ł30 heater control vaule with a little motor on it !!
Old Feb 25, 2010 | 05:20 PM
benjaminsarmy
i get all three stages of heat control but no heat got to be a air lock but why is the rad not fully getting hot only one side where the bleed pipe is .??
Old Feb 25, 2010 | 05:32 PM
benjaminsarmy
help please
to the top
Old Feb 25, 2010 | 05:36 PM
steves24V's's Avatar
steves24V's
we have changed to switch / complete heater control panel one at work done the normal valve as you have still no heat,
I take it you lost the heat one day rather than changed the coolant then had no heat.
Are there any signs of the head gasket gone as if there is air getting into the system via the head gasket the air will got the the highest point and the heater pipes are high on ka's.
Old Feb 25, 2010 | 05:53 PM
James998's Avatar
James998
Take the plug off the heater control valve, stick a multimeter across the pins and get someone to turn the heater dial in the car. This will help you rule out a faulty dial, i've had this problem before.
Old Feb 25, 2010 | 05:56 PM
Fil's Avatar
Fil
ELASTIC BAND
had this a few weeks ago, tho the ka was overheating big time, after changing all the valve bits then the the head gasket! found out the water pump was knackered, doh
https://passionford.com/forum/genera...ith-photo.html
Old Feb 25, 2010 | 05:58 PM
steves24V's
multi meter on volts dc ??
Old Feb 25, 2010 | 06:47 PM
benjaminsarmy
ill try its getting dark and my laptop is soaked lol meter is reading 13v on and off when switch is turned
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Rammer46
Sep 18, 2015 08:31 AM
cossie09
Sep 10, 2015 06:56 PM
BRAM
Sep 8, 2015 07:11 AM
