erst runs out of power
ive just been out 4 a drive in my s2 erst round sum
lanes in my area and when the revs were getting to
about 5000 - 5500 it just seemed to not want to go
any more,it was still on boost at 17psi has any body
got any idea what this could be,ive just put a different
intercooler on the car off of a saab so could this be
causing the problem
causing the problem
what size is the intercooler? is it bigger than a standard erst or about the same size cos if its the same same size your really on the limit and you will need a bigger one
possibly its commen sense really that air would flow down a straight pipe easier than round 10 90 degree bends so depends how much pipe work you have used really
ive got the standard charge carrier which goes to the intercooler
on the n/s of the car and then the other pipe from the turbo
goes along the anti roll bar then up and over the alternator
then through next to the rad on the o/s of the car
ballin, ye but the system might be pressurised to 17psi but the air flow might be piss weak. Hence not getting enought air fast enought????????????????
not really,the boost peaks at 18psi and holds 17 which i was
told was to much really for the standard intercooler,now with the
bigger intercooler it seems to go better up to the revs i said but
then its about the same after that as what the standard cooler was
havnt had it set up atall yet,was going to get that done in the
next few weeks at scc performance,theres no rolling roads
near me that i can go to or want to go to
rev limiter?!
Was hitting 5.5k in mine and sounded like i was on the rev limit! like a bouncing! only thing is i dont see how high it revs when in lower gears! ...im goin for a drive!
yes i did mention in another thread that im using a saab turbo
it bolted straight on but the exhaust housing and turbine inlet
inside diameter r slightly larger
