Any Window fitters or anyone fitted some themselves
got to change all the windows at home and have 1 which i think i could get done myself and save some dollar, and if its easy enough might attempt doing some of the others.
is it easy hard etc ? size wise wall to wall width is 119.5mm top wall to wood shelf is 118.5mm and wood shelf is 20mm thick so i presume actual window height is 205mm ? is it doesnt sit on the wood
id want double glazed with frosted glass and a air vent ideally slide so it can be opened and closed etc and the top opening
any ideas or help would be gratefully received.
Justin,
there very east to fit in.
just got to get the measurments of the opening right and get decent company to make the windows then fit them in using expanding foam and plugs screws etc....fit frame then the glass.
finished off with plastic beading if the gap is a bit big and them mastick all round.
easy.
easy.
shit happens
im a fitter mate an its a piece of urine, just make sure u measure the brick openin from the outside an deduct 10-15mm from width an height an when u order it tell them measurement is including the cill, pull the trim off the inside( run a stanley round it 1st to save the wallpaper/plaster, looks like u got an external glazed unit there so remove glass from outside by firstly pullin the rubber gasket out then the beads should just clip ott an then all the fixings will become apparent, just make sure u seal it all properly when puttin new frame in
liam
liam
your measurements are a little off id say mate ,id say 1095x1085.
it would be worthwhile measuring on the outside and measure to the cill as the window board inside can be up or down a bit .i would add 10mm to the wall to wall measurements as you will have to remove the inside reveals a bit both sides to get the window to fit in behind the plaster reveals on the outside if that makes sense.then add 5mm to the top reveal to the cill to give you cover on the top plaster reveal.
hope this helps a bit
cheers james
cheers james
shit happens
Justin,
easy.
easy.
it sounds like a scary job but once done very pleasing lol
turbocabessex where you located ? if near romford fancy having a look and maby a private job ?
what do you recon to this Ł160 and only in basildon, being stupid but i presume its including the glass and its double glazed
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_684wt_1167
09-10-2015 07:38 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
