Granny Cossie diff...............
07-01-2005, 10:23 PM
M8 has been offered a freebie one,are they the same as 2wd saph cos??????
If not exactly the same,would it fit???????
Thanks in advance
07-01-2005, 10:27 PM
there the same size as a 2wd diif mate as in 7.5" but they use 4wd size driveshafts
but i think they will fit in the beam
just got to change the shafts
and they have lsd
07-01-2005, 10:43 PM
same diff but different ratio and drive shaft ends
rob
07-01-2005, 10:54 PM
Do you know what ratio they are anyone?????????
08-01-2005, 12:13 AM
only lookin at it a few nites ago,cossie is 3.64.cant remember the grannys
its in the bible
rob
08-01-2005, 10:32 AM
Quote:
Originally Posted by Rob Virgo
its in the bible
rob
Which bible m8????????
08-01-2005, 10:36 AM
I thought it was just the input flanges that were different?
08-01-2005, 10:47 AM
Granny is 3.62 same as 4x4 mate
Means it can be used on 2wd and 4x4 just fine.
08-01-2005, 11:08 AM
So just stick 4x4 shafts on and he'll be laughin
Freebie too
08-01-2005, 11:21 AM
Check the tag. I've got a sneaky suspicion they're 3.3:1
08-01-2005, 12:30 PM
Quote:
Would that make it higher or lower geared??????
08-01-2005, 12:31 PM
08-01-2005, 12:32 PM
Cheers m8
gcfcos
59
06-10-2015 05:04 PM
Brickhouse
14
03-10-2015 07:28 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
