What turbo?
What turbo?
What turbo should i get for my Escort Turbo with the following engine spec...
1600CVH
0.5mm oversise pistons with 1mm machined off to lower compression
Lightned and balanced bottom end - flywheel, crank, pistons and rods
Ported and polished cylinder head
Piper T2 camshaft and vernier
Pace charge cooler (mite be being changed for a GRS cooler)
Scorpion exhaust
Bayoo chip
Do i go for a cossie 4x4 item, an off the shelf hybrid or speak to a turbo manufactur and see what they recomend.
Any advice/contacts much appreciated.
1600CVH
Scorpion exhaust
Bayoo chip
What bits do you use off the 4x4 turbo?
I persume you would keep the bearing housing and exhaust housing/elbow off the escort? It it just the compressor housing and shaft off the 4x4 turbo?
So i would be keeping the standard escort shaft/exhaust wheel and just fitting a new compressor wheel and compressor housing cover?
How would i go about replacing the 270bearing with a 360, is it just a straight swap of does this involve more parts?
Cheers.
Cheers.
i use a hybrid t34 its gr8 loads of boost all the time, when it was on the test bed at work it held 27psi peak 31psi now running 22psi peak dont want to fill it just yet
I got this from a website. They were testing all kinds of turbo's on an S2..
Finding the right turbo for the car took allot of trial and error, time and money. On and off the rolling road trying to find the best one. Many were tried and this one gave the best torque and bhp figures.
Stage 3 T34 hybrid .48 housing / 55 trim / 360
JK12
33
26-04-2021 12:09 PM
