handling probs...
Old Jan 6, 2005 | 02:18 PM
rapidcossie's Avatar
rapidcossie
Default handling probs...
had the bottom arms/ tca changed on my 2wd saf and it now handles shit!
understeers at any corner. had the tracking done as a matter of course. spoke to someone that said i must fit proper ford compliance bushes as the non ford items i fitted as part of the bottom arm will be heavy duty which is wrong? should they me just normal ones as only the diesls should have heavy duty?
my front tyres are now tottally worn on the inside edge after only 2k on the new arms.....did over 6k o the old setup with an even wear pattern??
also got a knock from the back left that only used to happen somtimes but now happens everytime i go over a bump, round a corner go on or come off boost...doing my head in. had a look for the obvious but nothing standing out. anyone any thoughts on any of my probs??
cheers in advance
Old Jan 6, 2005 | 02:51 PM
Neil S's Avatar
Neil S
Sounds like they've fitted the wrong TCA's to me mate
I've used the big doughnut bushes in my cossie rather than the std ford ones with no probs, so it wont be that
Neil.
Old Jan 6, 2005 | 03:12 PM
rapidcossie
all sierra ones are the same(except diesel) checked at ford... and i ordered them myself from local motor factors.
any other ideas?
Old Jan 6, 2005 | 07:59 PM
Neil S's Avatar
Neil S
Who told you that?
Go back and tell them to stop being silly and give you the correct parts
Neil.
Old Jan 7, 2005 | 12:32 PM
rapidcossie
so the cossie parts are diff from every other sierra?
the parts guy at ford said they were all the same...
Old Jan 7, 2005 | 01:13 PM
Neil S's Avatar
Neil S
He's an arse then
I got mine from a motorfactor, and checked the part numbers for myself in their books to make sure they hadnt fooked it up
Neil.
PS - did AVA do your car? what mods for 290 @ wheels? Bet that goes well!
Old Jan 7, 2005 | 01:16 PM
S1 Barkham's Avatar
S1 Barkham
Ford are useless, They told my mate that his car don't even have a Fuel Filter
Old Jan 7, 2005 | 05:10 PM
rapidcossie
ok will double check parts numbers and get the proper ones...anyone got the proper part numbers to hand??
AVA did all the tunning work on my car and the pistons are to their spec.
my car made 289.7 at the wheels holding only 20.9 psi.
spec is stage3 t34, greens, pro alloy cooler, bailey breather, standard airbox and filter
not really had a chance to try it out on new spec since the roads..sorry private test track up here in bonnie scotland have been generally too wet/covered in ice/grit to risk it.
had it wheels spinning in 4th at 120 on some ice then decided to leave it to another day!
any idea about the bump/knocking i mention in my first post
cheers boys
Old Jan 7, 2005 | 05:46 PM
rapidcossie
anyone got the proper part numbers for the arms to hand??
surely the wrong ones wouldnt fit?
Old Jan 7, 2005 | 10:59 PM
rapidcossie
up
Old Jan 8, 2005 | 12:32 PM
rapidcossie
cmon some one help me!
Old Jan 8, 2005 | 04:10 PM
Neil S's Avatar
Neil S
Sorry mate - my copy of microcat says that they're Non-Serviced. I'm sure they're available - just make sure he orders the right ones!
290 must be pretty damn fast - my stage 1 was 200 @ wheels (4x4) on their rollers
Neil.
Old Jan 8, 2005 | 06:17 PM
rapidcossie
when my car was stage one it made 225 holding 15psi, then it was 265 with my spec now but 4x4 cooler then by adding less than 2 psi and a pro alloy 500 cooler it made its 290. had it out today and had a bit of a moment on the motorway....new shape integra type r pulled along side so i dropped it to 4th and floored it(bad move) back end stepped out, not alot but enough to make you go oh shit when you going about 80! lol
thanks for you r help anyway neil...any idea about the knock i mentioned in my first post?
when were you up here in scotland?
wowk
Mar 30, 2021 07:49 PM
Jun 26, 2017 06:18 PM
turbotrev
14
Sep 27, 2015 10:44 AM
Kam B
Sep 24, 2015 10:40 AM
focuspower
Sep 19, 2015 08:27 PM
