1999 Ford Ka steering lock
Are these purely mechanical or partly electric.
Earlier this week, mine stopped engaging when I removed the ignition key. Two days later the battery was flat (it wouldn't even turn the starter motor).
An overnight charge worked, as did the steering lock.
The battery is the original, so very likely needs replacing. But if a faulty steering lock is somehow draining the battery, a new battery will still suffer from the same problem.
Thanks.
It was the fact that the steering lock didn't work when the battery was flat, but did after an overnight charge that made me think there might be a connection. If you're saying the lock is purely mechanical, I'll assume it was just a coincidence.
JoeyBoyden
04-01-2024 02:36 PM
borboyous
22-08-2015 11:17 AM
Jack and the Beanstalk
15-08-2015 04:27 PM
