Draft excluders - any that actually work?
Think I need one for my hallway door - getting a fairly strong draft from it (considering there's a good 5mm gap!)
Anyway, are there any that actually work? Or is the good old "brush" one actually worth fitting?
brush ones are ok, but will need to router door if you want them in the door, or you can get ones that screw to the frame. you can also get weather bars to go under the door and when you close the door they push down and seal against the floor. hope this helps
Resident Wrestling Legend
you get them little rolls of foam that have the sticky stuff on them
i simply put a doule layer on all the gaps, as in twice the width not one over the other, and it worked a treat
mind that you don't make the gap too tight as the door own't close properly afterwards without a BIG shove
What about one of those snake draught excluders ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
http://www.idealmoments.co.uk/viewEc...productid=4629
in which case, you'll either have to get something front and back of the door to get it closer to teh floor or have one of them brush things on the outside and put a strip of carpet up inside when you go in
JK12
33
26-04-2021 12:09 PM
Rstar_man
143
20-07-2020 11:16 PM
