Ignition Surpressor on coil.....
GASH!
which side of the coil is it supposed to be plugged in? mines been disconnected and i can hear the spark through the stereo. well annoying.
LIVE side of the coil low tension wires, I would suggest around 1uF should do it, do NOT alter the length of the wire attached to the capacitor/suppressor as this can kill higher FM reception.
If it is line born interference a 16Volt 1000uF electrolytic capacitor can be inserted in the live feed then earthed, or use a LS630 or equivalent choke.
