diffrence between cosworth big turbo and small turbo engine?
What is the big diffrence between these? Can the small turbo engine handle 500BHP?
from what i can remember these are whats different
block has oil spray jets instead of a bar off the oil pump
head
inlet
ex manifold
crank pulley
management
turbo
cam cover
it doesnt run a dizzy and is on seperate coils
the small turbo engine is the best one to use out the lot i was told aswell as everything is far better, better oil design with the spray jets for one, bigger inlet, and im sure i read the head is better than a big turbo once flowed
head
inlet
ex manifold
crank pulley
management
turbo
cam cover
Although more responsive than its big turbo relation, the small turbo engine is very lmited in scope as a base for a big power engine. It has fords own engine management on it, EEC VI i think, which is the main weak link.
Monte 087
Its only the management thats the limiting factor with them, the engines themselves are a very good basis for big power builds.
big_Rad
15-09-2017 09:36 AM
