Engine management light on a 3dr staying on
been out 2day to look @ a 3dr for one of my m8's car was very clean and drove without any faults that we could see apart from the engine management light was on all the time
the bloke who's selling it said that it had only started to came on since he had the greys (403's) fitted to it 6mths ago and said it was fine b4 when on greens (803's) the car is running a L6 ecu if that may make a difference, the car to me seemed fine apart from the light being on constant
any suggestions on a post card
ps HE did say he was going to just take the bulb out but DIDN'T get round to it as yet
i dont know the exact cause, but i do remember Stu MSD posting about this a while back... i dont think its anything to be alarmed about though....
maybe do a search for Stu's post.. it tells all in that HTH
Originally Posted by GARETH T
its something to do with when you write programs for the chips,, sometimes people dont remove the overboost safety light output
Daveyboy thanks also will do a search as well
HOW's your motor doing??
https://passionford.com/forum/viewto...714&highlight=
done a search for stu @ M Developments... tis on page 28 FAO 3dr owners!
Saphs getting there... picked up 4x4 bonnet yesterday just gotta put it all back together now and get it painted!! ta for askin
Was it on on intial start up and then come when boost applied.If this is the case then who chipped it hasn't taken out the overboost warning and it lights up but should go if you turn the key off and on again(obviously not whils't driving ). This is nothing to worry about as said above.If it is on ALL the time i not sure about that.Best speak to Stu.He the man.
Originally Posted by TIFF-C20WTH
As Garerth said
Nothing to worry about
The only problem with the light being on all the time is you wont know if there is a problem i.e a sensor down which would normally switch the light on to tell you there is a problem. As its on all the time you wont know this
That is correct, but that wasnt in the thread when i replied
its always worth having a remap for piece of mind though
i know when Stu writes this programs, the light will not come on but he does sell off the shelf chips for grays!
its always worth having a remap for piece of mind though [/quote]
DONT think Stu, sells off the shelf chips for Greys a re map will BE on the cards if he buys it
Stu @ M Developments
41
21-08-2015 07:47 AM
