solid followers
Old Nov 29, 2009 | 04:25 PM
cossyking's Avatar
cossyking
Default solid followers
im building a new engine for my 3 door ele, big spec wheres the best place to get solid followers and shims and can you use 1.8d ford ones as ive been told these can be used
Old Nov 29, 2009 | 04:35 PM
forevaford's Avatar
forevaford
ul need good valve springs with the diesel ones as they are heavy. if its turbod yb then standards are ok up to 8k rpm in my opinion
Old Nov 29, 2009 | 04:44 PM
cossyking's Avatar
cossyking
the cams im running the mapper said i need solid, what springs do you need
Old Nov 29, 2009 | 05:00 PM
B13 JUS's Avatar
B13 JUS
newman double valve springs are good because there's no modding required to the head.
i think stu @ motorsport developments sells them on his ebay shop.
what cams are you running and what power?
Old Nov 29, 2009 | 06:22 PM
Rs1's Avatar
Rs1
steveboyslim can supply solids and shims, pretty sure he'll have them on the shelf. Just drop him a pm.
Old Nov 29, 2009 | 11:05 PM
polly_x's Avatar
polly_x
Why not ask your mapper? If he knows more about the cams than you then surely he/she can advise on correct springs? You need to know the cam specs to decide on springs to avoid any binding issues.
Personally I would get a Cam/Follower/Spring combo set from whoever ground your cams to avoid any expensive issues.
If you do know them and need the followers and shims then Steve Slim will no doubt have the Arrow ones on the shelf.
TPM961
Jan 15, 2018 10:50 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
SMILER258
Sep 28, 2015 09:04 AM
