struggling to get to grips with 4wd
hi all, i posted the other day about my 360dg spin in the evo but it was in the rain, now today roads were dry and at around 80mph i just tabbed the brakes maybe just a tad to hard and it was on a very slight right hand bend and the back end stepped out again!! i was ok tho just come off the throttle for a second and she was in a straight line again, ive got toyo T1R,s on the front and ive got yokohama DNA GRAND PRIX on the back but the back tyres are nearly at the end of there life so will be putting some TR1,S on.
there still on standard 16in rims and will put 17in on when i can afford , i realise that it is me that has to learn more about driving 4wd and AYC (active yaw control)
ive also looked into the tyre pressures and peeps are saying 30 in the front and 28 in the rear
thanks
andy
thanks
andy
maybe the tracking or a brakes issue, as i know you said it was exiting a roundabout so im pressuming you braked before it, so maybe a back brake sticking on
only guessing though
but i realy dont think it should be behaving like your saying it does
andy
sounds like a plan mate, i wouldnt want to be driving it around for too long without having a good poke around, good luck
Dont think the ayc will do much for lift off oversteer, youve got to be on the power for that to work. Try scrubbing the speed off before you enter the corner and try not to be on and off the throttle mid bend as it'll upset the balance.
Carbon Crazy
remember being 4wd you can have understeer, power oversteer, lift off oversteer, the whole lot
But as said, if the car seems out of control get it checked.
Most 4wd cars are tame, understeer can be fixed with oversteer and 4 wheel drifts, lift off oversteer can correct into a night bit of gentle power oversteering rather than snapping back straight hard etc etc
Boost Junkie
sounds like you cant drive well at all, aside from potential problems with thae car. Poor workmen blames his tools and all that....
http://www.evo.co.uk/trackdays/theory/archive/
good bit of reading^
That's true, but on the road at times(although you maybe shouldn't be doing it anyway), you need to slightly change your line to accommodate cars coming the other way etc. You should still be able to do that and have control with feel. If the car is unpredictable then there must be something wrong somewhere... or maybe the OP just isn't used to 4wd yet.
Unknown.
AYC is a pain to get used to apperantly, I knew a guy with a Evo 5 and he kept spinning out in the wet or dry, If you keep on the power it'll correct itself and be fine providing you know what your doing.
Never driven with AYC, so only going on what he said. Braking mid corner is a big no no, even in a 38bhp Mini
you say your back tires are on the limit? get them replaced then see if its the same.
got three barely legal tyres on the impreza and lately (with all the rain) the arse end has been coming out at almost every rounabout, suprising how much difference they can make, never noticed till now.
just finding my feet
worn out rear tyres and braking mid corner is the problem,,,, nothing to do with the amount of driven wheels,,,,,,, the problem seems to come from between the seat and the steering wheel IMO
ive got 4wd and ive only ever span the car/had issues due to my shite driving, worn tyres make a HUGE difference to a car aswell
ive always found evo's to be twitchy in comparison to say an impreza.....
it may be my style of driving that doesnt suit or something daft like that.doesnt anyone else feel evo's to be like that?
only times ive span out is when i'v been cocking about, well, apart from the last time, dont know where that came from, must have been a bit of diesel on the road
Only when off throttle.......which imo would suggest the balance of an standard evo(5/6) is not quite as good and an old scoob(the evo lot will hang me for that,lol). Youve got to get used to keeping on the power though for any 4x4 to work though. Instinct makes you jump off the throttle when it gets a bit lairy. If you cant learn to keep you foot in then the next best thing is when you lift off to hammer the clutch in asap to help balance the car, then when its back in line set it away again. This is slow on track but for general purpose is fine and could well keep you out the ditches,lol.
2Evos & 1 Escort Van :-)
Too tired (there's a pun there, boom boom) to read all replies, but I reckon it's your mismatch tyres.
I'd be 95% sure of it in fact.
Change them to all the same size, tread depth and make and model.
T1Rs are very different to T1S, bin them all off and start again IMHO.
Yep it costs lots, but to offset it, sell them on to some other mug who doesn't care enough about his handling, job done!
rear tyres are nearly at their end of life and you go in to a 360 spin in the rain, then you say it does it at 80 mph in the dry and you didnt do any damage ?????
i dont beleave any of this and what speed was you doing in the rain then with them tyres being low, dont get me wrong we all speed but with low tread depth i wouldnt dream of putting my foot down..
also you should have all the same tyres with the same tread depth on a 4x4 it makes a big diffrence
