fuel hose
hi guys
please help
been looking on the web for tips on running fuel lines in my escort mk2 rs2000 fitted with cosworth engine
anyway
going what i found on the wed ive gone out and got my self 10m of 6mm bradied hose and fittings
just got home from work and looked at the alloy tank in the boot and the 6mm hose doesnt fit over the fitting sticking out of the tank
have i asked for the wrong hose?
have i got the wrong info of the web
please help
please help
anyway
please help
Drives Nova & VW Golf!!!!
Hi
I run fuel lines inside my, dare i say on this forum...........Nova.
I would say you need dash 6 (-6), not 6mm hose.
One think i would say if you can afford it go for the fuel hose that has a plastic coating over the brade. Braded fuel lines allows fuel vapour to seep through and makes the car stink!!! The plastic coated is about 3 times the price though.
![](http://i12.photobucket.com/albums/a220/NOVAMARTIN16V/NOVA%20PICS/Picture004.jpg)
If you look here it tells you sizes http://www.bgcmotorsport.co.uk/newfuel.html
-6 hose is actually 8.73mm internal which is probably more like what you need.
Martin
Martin
No worries mate.
Just measure the external diameter of the pipe your trying to go over to make sure it matches up with -6
Dont want to be responsible if i've given duff info
Just had a scoot around the web but cant find it.
Can see mentions of it on GTR furum etc.
I think its either PTFE or Teflon coated you need.
If you ask your hose supplier i'am sure they can advise.
When i was offered it from my supplier it came out if i remember about £70 per metre!!!!!!!
Use OPA, no smell, cheap as chips, VERY tough and resistant to all oils/fuels, and can take air pressure, so use as other things like air comp hose etc, will be rated at 25 bar.
Russ Payne
25-09-2015 08:29 PM
