Vacuum hose
Hi guys just done the head gasket on my escort running well but was a bit sluggish on boost. Hope I've got the pipes on right theres 2 small pipes coming from the turbo going to a round electronic thing on top of the gearbox don't know what it's called also looking at the fuel pressure regulator the a point on it like it should be connected to vacuum but it's not have I missed something out putting it back together any help will be great
The pressure regulator should not have any Vac pipe on it.. its preset factory to 85/90 psi..the valve with the 2 small Vac hoses is to protect over boost...does not matter which way round they go. hope helps ....Peter
