So whos blown or know someone whos blown a diff with a gripper or quaiffe internal?
i'm in the market for a new diff maybe this month but i cant decide which internal to get one with....
from what ive seen, the quaiffe tends to be kinder to the crown gear and pinion, as ive seen some stand still burn outs done with a 420bhp rwd escos and it took that with the brakes appiled slightly and drove away..
ive also the same stunt done with a gripper and the crown gear exploded...
so i'm not sure what to invest in as i want to give lots of abuse and also i'd want it to be good for drifting...
any ideas?
cheers my escos is rwd..
any ideas?
i got a 71/2 inch in my 3 door quaife and i broke it. it was the pinion tho not diff now fitted uprated crown and pinion and its spot on. quaife say a cosworth wont produce enough power to kill there diffs
I've got a gripper I broke the cross shaft in it once in 4years of use. You have to get gripper diffs rebuilt every couple of years as the preload drops off.
Grippers are more lively than Quaifes they drift like a welded diff as they lock up.
Abuse will break either but IMO for fucking about you can't beat a Gripper.
MAD Carbon Cossie
For fu*kin about you cant beat a welded
Did a Gripper, done crown wheels, snapped a pinion in half, the bell that slots through & bolth the drive shaft to, snapped one of them as well. Think I've busted a bust in everyway possible
For fun & cost, you cant beat a welded, if you can live wit the slow speed whell scrub that is
jb
jb
Never broke my Gripper, its been in the car 6yrs and prob done a good 12,000 miles and this year spent a day at pod doing 7k launches on drag radials all day long, sent it to Bara to reset the pre load etc and give it a full check over, Bara stripped it down and all it needed was some new bearing but he said they were not overly worn and that the diff unit was spot on.
Cannot fault it.
Cannot fault it.
the gripper diff in kennys 500bhp focus cossie has been around us for 10 years been rally cars track cars had loads of abuse with no probs. quaife is a good strong diff too thou but not a great lsd
jb
jb
ive got 2 2wd cossie cars with quaife in and given a lot of abuse for years and never broke em. padle clutch, fast launchs doughnuts and lots of sideways still very good
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
DavidK
27-09-2015 02:55 PM
