Wossner pistons??? dose any one use them or had any problems ect ect
YES I KNOW I CANT SPELL
sounds good get sum pics up of your s1.... it looks good whats your spec?
Guest
Posts: n/a
As with everything mate some will like and some won't TBH,
Look at newman cam's they can kill an engine but people who have it set up right there perfect
The Spec mate well TBH what isn't done is more to the question LOL the only thing i couldnt afford was EFI,TBH i concentrated on engine strength and beating it around a course.
formerly beefy-rst-2
the maufacturer recommended a set clearance , wich nash specced to ,
he even said himself if he had supplied them to the engineer and said match these clearence wise , it wouldnt have been a problem ,
just double check clearences when boring block to suit ,
few folks i know have them in big power rst's with no issues ,
beef
we had them in our old cossie, but when the block was machined, i personally dont think the machine shop did the piston-bore clearance big enough, as it nipped up and melted when was being set up not long after rebuild
I specifically remember the man telling me that he had made the clearances tighter to reduce piston slap
Sarah
Sarah
Cake lover!
The problems i had had are massive piston slap after 1500miles of use[was really quiet when first built], still there now as i cant be arsed to change them. Car doesnt use oil, doesnt smoke, has good oil pressure, and makes good power. Sounds like a tank on start up but cannot justify the cost of a rebuild when theres nothing else wrong.
The reason i had my machined the way i did was because wossner said i must do it this way. They said they need extra clearence and if i didnt do it to there measurements i ran the risk of it seizing up.
I will go Mahles next time.
Guest
Posts: n/a
And if i do i am gonna set the fooking car a flame
DixieTheKid
11
06-06-2020 11:20 AM
