having probs with zetec conversion????HELP
Old Oct 15, 2009 | 08:29 PM
mk4 kabby's Avatar
mk4 kabby
Default having probs with zetec conversion????HELP
hi evry 1 i currently am putting a 1800 zetec engine in my mk4 escort cabby and have come across a problem . i read somewhere that you can use the 1.8 gearbox but no one says how .they all seem to use the xr3i box but the hole in the clutch is much bigger on the 1.8 engine so tryied to put xr3i clutch n flywheel on but the flywheel bolts are to big so i dont know if i need to drill the holes in the flywheel?? or does any one know how i can mount the 1.8 box .thanks any one who can help
Old Oct 15, 2009 | 08:45 PM
Rick's Avatar
Rick
you can either drill out the flywheel bolt holes on the cvh flywheel (only of use if it has the holes in the back for the cps pickup) or use an 1800 zetec flywheel and the cvh clutch.
Old Oct 15, 2009 | 08:52 PM
mattxr3i's Avatar
mattxr3i
watch out though as the 1.8 130 spec on the '3i had a 240mm clutch due to using the MTX75 gearbox
Old Oct 15, 2009 | 08:54 PM
Rick's Avatar
Rick
yea, it needs to be a 1.8 zetec flywheel off an IB5 gearbox
Old Oct 16, 2009 | 09:37 AM
mk4 kabby's Avatar
mk4 kabby
yeh tried cvh clutch on fly wheel the holes dnt line up so i guess its the mtx75 as the 1800 is the 130 ps.so basically my options are drill the cvh flywheel or buy a flywheel from an ib5 gearbox? whats the differance between the ib5 and mtx75 would i be able to mount the ib5 box easier than the mtx75
Old Oct 16, 2009 | 09:47 AM
kniterider's Avatar
kniterider
mtx75 has another mount on it and also has a lift up style reverse gear, i believe it is the stronger of the two gearbox's but might be harder to fit.
Old Oct 16, 2009 | 10:20 AM
mk4 kabby's Avatar
mk4 kabby
oh rite thanks .dont supose you can find info anywhere on how to do fit i cant find anything .im starting to regret this conversion .lol
Old Oct 16, 2009 | 05:49 PM
xrmalin's Avatar
xrmalin
Drill the holes out in the cvh fly wheel its only 1mm i think from memory then your clutch should bolt straight up.
I wouldnt bother with the mtx box as said its a stronger box but then you need to have custom drive shafts made up and new mounts.
The power that your going to be running will be fine for your 3i box mine has been any way
mark.
Old Oct 17, 2009 | 06:11 PM
mark_24v_wiring's Avatar
mark_24v_wiring
You will need to use the Zetec flywheel if your cvh flywheel is not an EFI one, if your running std engine management, and then fit a rst clutch (220mm) to the zetec flywheel and bolt up the 3i box or find an IB5 box from a mk5/6 escort that has 4 bolt holes in the front casing like a mk3 gearbox down side is that puts the starter on the back but then you can use a clutch from a mk5/6 escort
Old Oct 17, 2009 | 08:02 PM
mk4 kabby's Avatar
mk4 kabby
ah wot more money 2 spend !so i need 2 get a rst clutch or a efi flywheel i guess flywheel prob cheaper option?thanks for ur info most useful
Old Oct 18, 2009 | 08:27 AM
mark_24v_wiring
Dont forget if you do get the efi flywheel you will still need to make the holes bigger to fit it to the zetec crank and as said above you will need a zetec flywheel off a 115ps 1.8 zetec and not the one you got as it sounds like you have the mtx75.
So your left with 2 options
1 buy a cvh efi flywheel drill holes bigger and use clutch you already have.
2 buy a zetec 115 1.8 flywheel and an rst 220mm clutch.
It really depends on how old your clutch is already as if it was me i would be fitting a new one any way just to save the hassle of fitting one in a few months (yep been down that road before lol)
Did you get the engine from an escort or was it a mondeo?
My mk3 undergoing a dummy blacktop and ib5 box fitting
Only reason i used the ib5 is to put the starter at the back as my manifold is too tight to the block to allow fitment of the starter at the front of the engine but then it was designed for a focus 2.0 blacktop which has the starter at the back any way and i get all the bolt holes using the mk4 box you wont be able to fit 1 bolt at the back where the starter would go as the lug on the engine is not there but dont worry its not a problem i ran like that for 2 years or more without problems.
I really miss that car should never have sold it wife has still not forgiven me lol
Old Oct 18, 2009 | 08:55 AM
mk4 kabby's Avatar
mk4 kabby
engine is from 1.8si 130ps escort ! think i will try find the efi flywheel as me clutch is gd ! thought thiswas all gonna be simple thats how evryone made it out to be on the net lol and no u shouldnt av sold it lol
Old Oct 18, 2009 | 09:01 AM
mark_24v_wiring
It is simple (when you have done 3 or 4 you kinda get the hang of it lol) have you modded the drivers side engine mount yet? 1 bolt hole dont line up more things to mod lol.
Yeh i know i should of kept it thats why im building a better 1 now lol
Old Oct 18, 2009 | 10:15 AM
mk4 kabby's Avatar
mk4 kabby
havent botherd with the mount as most people dnt seem to bother they say 2 is fine !maybe a bit ov locktight 4 peace ov mind! lovely old job hehe. still tryin 2 find a flywheel though!! just want my baby back on road !drivin me m8s astra is drivin me nuts !!
Old Oct 18, 2009 | 10:27 AM
mark_24v_wiring
Getting a cvh efi flywheel could be an issue but im sure someone has one somewhere shame on you driving an astra pmsl
Old Oct 18, 2009 | 11:03 AM
mk4 kabby's Avatar
mk4 kabby
a guy on here got one but in glasgow am gonna see how much a courier will be? and yes ur rite shame on me lol. oh and someone told me about a thread called another orion project and some one posted the wireing instructions can u check it out and tell me if thats all i need to know ?? cheerz
Old Oct 18, 2009 | 05:51 PM
mark_24v_wiring
https://passionford.com/forum/restor...n-project.html
Thats the post with it in should be ok as long as you know what your doing you should be able to make it work
Old Oct 19, 2009 | 11:03 AM
mk4 kabby's Avatar
mk4 kabby
will a efi flywheel from fiesta xr2i be ok and will my 3i clutch fit it ??
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
