Twin Scroll Technology with an uneven number of cylinders
For the turbo gurus out there I was wondering if there would be anything to stop one using twin scroll technology on say a 5 cylinder engine?
Even if one could use a standard turbo, if an OEM wanted to, could they design a turbo with two different scrolls suited tot he different volumes of exhaust gas (3 cylinder against 2)
Just curious!
Just curious!
Resident Wrestling Legend
but nowadays you can use twin turbo's on 4 pot engines so the jump to a 5 pot won't be that difficult IF you work out which clinders produce the best flow lower down and which produce the best flow higher up
or design a manifold to produce these particular effects, much like the old 24V vauxhall lumps which were split to run as 2 3 pot units below a certain rpm and then as a combined unit higher up the rev range
*** Sierra RS Custard ***
Very interesting question!
Sadly I havent ever seen it though so cant help.
I would imagine that the VE difference between the two and the three wouldnt be enough to cause any major problems.
Have you asked Russ if his is a twinscroll? I know mark loves them so it wouldnt surprise me.
There is a pulse every 72 degrees, so you would end up with something like:
Side a: 72, 144, 288
Side b: 216, 360
But you could easily smooth those out to be fairly equally spaced at the point in the rev range that you are interested in by altering the runner lengths.
The standard Volvo manifold is unequal length in the first place bespite being fed by all 5, so the standard turbo gets an uneven pulse in the first place, doesnt stop it working well.
Ali, are you asking because you have access to a cheap divided flange turbo (ie an EVO one or similar) and want to know if it will be "ok" or are you asking because you want to know which is optimum on a 5 banger, twin or single entry?
Cause the other option of courseon a twin scroll is to use it like a normal turbo and simply join the 5 in the collector so they all see both sides anyway.
Evo 8 (or better but more expensive an evo 9 unit in the same housing) turbo on a 10.5 housing looks like a nice alternative to a GT3071R with similar spool characteristics, but if you can't use the twin scroll aspect then its only as good as any other TD05.
I can run a broadly available cast manifold from an S60R
which is proven to 420bhp and has a standard mitsi rectangular flange on it,
Pic shows my standard manifold on the left, S60R one on the right and the flange layout:
so if i use this Id b better getting a plain old td05-20g off a subaru or other (round entry) and using an adaptor plate.
Subaru flange:
If the twin scroll thing will work and is worthwhile, then I will source an evo 8 turbo and the correct housing (Tathan has one) and ask Gav if his offer to build me an experimental manifold still stands.
evo flange:
Subaru flange:
evo flange:
Happily retired
Mark
So you reckon it wouldnt just not give the advantages of a twin scroll turbo but it would actually be worse than a conventional single scroll turbo?
Thanks for the Gen Mark.
I guess to cope with the different volums of gas youd need a exhaust housing with different volumes and to cope with the different frequency of pulses you would need the two parts of the exhaust turbine to be doing different speeds ideally?
Surely if you ran 1, 4 & 3 to one side and 2 & 5 to the other it would be fine? I've got something in my head saying Charade GTti's ran twin-scroll
Hi all i did as the Shead his advise on this a while back as the twin scroll would be nice to try on the volvo thanks for thinking of me
Maybe one day if only i can keep the gearbox in one piece
Russ
Russ
Testing the future
Steve Escos
01-10-2015 06:57 AM
850, cosworth, cylinder, fourpot, housing, manifold, s60r, scroll, technology, turbo, turbocharged, twin, twinscroll, volvo, work
