Zetec-s engine conversion
My mate has a 2002 Fiesta Zetec-S and wants a bit more power. He was wondering if a 2.0 Zetec would go straight in? If not what other engines will fit nicely and give good power gains? He's not keen on the 1.7 Puma conversion which I suggested to him.
Any help is appreciated
Drop in a 2.0L on bodies... we do them for £2,300... New engine, jenvies, ECU all ready to run at 170BHP
Add some cams and you get 195 ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
http://www.mtechautomotive.co.uk/engine-packages/
Matt
Matt
No engines other than the 1.7 puma engine (or the 1.6/1.4/1.25) go straight in, all other conversions require different mounts/gearboxes/wiring looms etc.
Well it depends on what you want to ultimately use.
The XR2i, I would only get the 1800RS, and is because it has silvertop mounts etc, but note that the silvertop mounts do differ from blacktop (and indeed ST170) mounts.
Budgetwise, for something lie, this, we would quote £4,500 for installation and mapping of a Zetec 170 pack, but thats obviosuly garage rates. On your own your looking at maybe 4 options:
Duratec HE:
Mounts *may* be similar as the engine is still reversed, and being basically a Mazda should be ok with the fezzy mounts IIRC
Zetec Black:
Good range, 1.8/1.8/2.0
Good engines, about £2.5K would see TBs, ECU and a new block (thats our price, OMEX engine, £4,300). Shares the camcvoer style end mounts as your current motor.
Zetec Silver:
Probably not worth doing, mounts would be interesting, being the fezzy has engine end mounts not back block mounts
Puma 1.7:
A lot of money for not much of a jump, maybe 145/150 after you have TBd it. Drop straight in IIRC
CVH Turbo
Always fun, mainly surpaassed by the ZT, mountings may be interesting as uses block mounts.
ZT:
The way to do it, budget £5k by the time you have got it all mapped up, and thats doing it cheaply I would of thought.
Hope that helps, depends on what power your after and your budget really..
Matt
Duratec HE:
Zetec Black:
Zetec Silver:
Puma 1.7:
CVH Turbo
ZT:
Matt
cheaper to tune it
Decent manifold and exhaust, standard inlet, shawspeed ss4 cams and uprated rodbolts ( again from shawspeed ) and valve springs will see 150bhp once mapped
proven and cheaper than buggering around putting in a heavier engine
restrictions on the standard engine are ehxhaust manifolding and cams/cam timing to meet emmissions regulations for new engines......simply knocking the exhaust cam back by 10 degrees on a standard car with a decent manifold will take it close to 125 bhp
ps, the only gearbox that works on a zetec-e into fiesta would be the rs1800/16v xr2i ib5 box
utter PITA to transplant for very few gains unless you go turbo
Shawspeed can offer various specs to over 200bhp for the 1.6.
It's used in many caterhams/westfields from the factory as it's light, revvy and very very tuneable
seen plenty of them
Probably with using 1.7 is the lack of off the shelf parts such as forged rods and pistons.
They have a good crank as standard, but 1.6 crank will take 9k all day.
Cheaper to tune the 1.6 if going to a decent S1600ish spec.
