if i unscrew this...
Old 16-08-2009, 09:07 AM
dojj
Resident Wrestling Legend
dojj's Avatar
Default if i unscrew this...
will i loose all my a/c gas?
the one i've removed from another car has got one of them tyre type valves in it so before i get busy i just want to check
cheers
Old 16-08-2009, 09:15 AM
markk
markk's Avatar
no, the pressure switch should always have a shrader valve connection
Old 16-08-2009, 09:20 AM
dojj
dojj's Avatar
right ho then
how do i figure out which is the low and which is the high pressure?
this ones on the smaller pipe that comes from the condenser (the front rad) and the other one has 4 wires and that pipe goes to the pump
Old 16-08-2009, 09:27 AM
jonesymk2
jonesymk2's Avatar
some cars have H and L on the caps that you take off to regas the system,so whichever cap is on the small pipe will tell you
Old 16-08-2009, 09:38 AM
whilee
founder of chicken porn
whilee's Avatar
i wouldnt touch it but then again i dont know a single thing under my bonnet my aircon is when i have the window open driving fast
Old 16-08-2009, 09:41 AM
COLEYST200
COLEYST200's Avatar
why do you need to take it out ???????????
Old 16-08-2009, 10:22 AM
dojj
dojj's Avatar
one of the switches is fubar
either high or low pressure
the a/c works for about 20 minutes and then stops so something is tripping out
the switches are the main culprits as even with the engine running and left standing there is no water puddling underneath and the only other thing it can be is the expansion valve
apparently
it's got gas in it
all the mechancials are working and new as far as the pipes, condensor.drier, etc are concerned and it's got the full complement of gas/dye/oil in it as well
Old 16-08-2009, 10:52 AM
T3ORA
T3ORA's Avatar
apparently
it's got gas in it
does the cooling fan run when the a/c is on
Old 16-08-2009, 11:15 AM
Lee Ivatt
Shizzle My Nizzle
Lee Ivatt's Avatar
apparently
it's got gas in it
Having the same problem with my mk5 golf, re gassed and everything and still like a greenhouse inside the car
Ill put a spanner to anything
but Air con has always seemed to be a mystery to me. And the pipes always seem to be in the way (note cambelt change on cossie )
Old 16-08-2009, 11:29 AM
RichieST
RichieST's Avatar
High pressure is the thin pipes, low pressure is the fat pipes
Old 16-08-2009, 12:21 PM
dojj
dojj's Avatar
apparently there is also a shim kit for the compressor where you take the wheel off and put a slimmer shim in the way and it all works
but this doesn't seem to be my problem as it's done it for the past 3 years, it works sometimes, it won't work at other times, and then for months at a time there will be nothing wrong with it at all
Old 16-08-2009, 01:33 PM
SiZT
SiZT's Avatar
Take it to someone who properly knows about air con. Which should be everyone who works with R134a now!
Old 16-08-2009, 01:37 PM
RichieST
RichieST's Avatar
I agree. Fucking about with it when you don't really know what your doing is just going to make the problem worse.
Get it to someone who does
Old 16-08-2009, 01:41 PM
Big G
Big G's Avatar
Thats everyday life for Dojj
Stu @ M Developments
41
21-08-2015 06:47 AM
RS_JAY
25-03-2005 10:42 PM
RA052824
17-02-2005 06:29 AM
Bruce Read
40
27-01-2005 03:53 PM
Quick Reply: if i unscrew this...
