2.0 306 hdi rattle till 3000rpm then clears........
Old 16-08-2009 | 08:40 AM
Brasso's Avatar
Brasso
Default 2.0 306 hdi rattle till 3000rpm then clears........
Just bought a cheap 1999 306 hdi for work, nice little car but on hard acceleration theres a loud rattle sounds similar to surge.
After googlin it theres seems to be mixed opinions on the cause, some say crankshaft pully others say injectors etc just seems weird that it clears at around 3000rpm
Has anyone experienced similar?? Just want to try and make sure its reliable cus i do 500 miles a week but dont wanna spend a fortune replacin things that dont need to be.
Old 16-08-2009 | 10:00 AM
Madbradz's Avatar
Madbradz
Crankshaft pully... Very common on them.
Check out pug306.net
Adam
Old 16-08-2009 | 10:05 AM
Csm's Avatar
Csm
Yep very common
I had a 306 hdi untill it developed a fooked injector........Ł250 each x 4 exchange and needs put on the dealers diagnostics to reset the injectors
Big bill for a shitty pug fook that
Old 16-08-2009 | 01:20 PM
Brasso's Avatar
Brasso
Adam
Cheers mate.
Do you know if its an urgent change when it rattles or can it wait a while??
Old 16-08-2009 | 01:25 PM
xrsi's Avatar
xrsi
its a rubber damped pulley, thw rubber in the middle perishes and makes the 2 halfs rattle, very common on all HDi engines.
isnt a must do straight away but do it soon as possible as it will only get worse, oh and use genuine parts as pattern ones are crap! had a pattern part on the ex's 206 and it went 18months later again so was false economy to save a little in short term only to have to do it again so soon.
Old 16-08-2009 | 01:33 PM
andybrst's Avatar
andybrst
hiya guys i am a peugeot technician the pulley is a very common fault on them just to be 100% certain it is that if you put the car in full right hand lock and remove the little arch liner behind the wheel you will visibly be able to see the pulley rotating on the piss also if you do require one i could get one for you at trade if you would like and post it
Old 16-08-2009 | 02:39 PM
Alvyn's Avatar
Alvyn
I've got a rattle on the mrs 206 1.4 HDI could that be the same problem?? have removed the alternator drive belt and there is no noise?? changed the tensioner as we thought it was that cos we could see it bouncing as you looked at it but noise is still there!(If you dont start the car up for a few days the noise is well loud till it warms up a bit!
Old 16-08-2009 | 03:03 PM
andybrst's Avatar
andybrst
that will more than likely be the bearing in the alternator thats quite common in fact i would put money on it being the alternator as i did one not long since at work.
Old 16-08-2009 | 05:14 PM
Brasso's Avatar
Brasso
had a look like you said and there is a little wobble, its deffo not runnin true so probally the cause. Ta mate. Gonna get the cambelt done and have it serviced do they need all the pullys changing when the cambelts done?? Cars just done 135k
Old 16-08-2009 | 09:22 PM
andybrst's Avatar
andybrst
no mate when you get the cambelt if you get it in a kit you will get the tensioner as part of the kit, glad i was able to help keep me posted on how it goes any more help just drop me a pm
Old 16-08-2009 | 10:30 PM
Brasso's Avatar
Brasso
Nice one mate. Just out of interest is it just the speed the pully is turning at 3k that makes the noise go away?
Old 18-08-2009 | 07:05 PM
Brasso's Avatar
Brasso
Hi mate how much would the pulley be?? Is it an easy swap?? Thanks again
Old 18-08-2009 | 08:38 PM
andybrst's Avatar
andybrst
hiya mate yea the pulley is a piece of p**s to do. first of you will need a 13mm spanner to release tension from the auxilary belt but make sure you note down or draw a diagram of the route of the belt then just whip the bolt out of the pulley 22mm i think and the pulley will come off. when refitting the new pulley make sure the locating cut out on the pulley lines up with the key on the crank the tighten the pulley up and refit the belt and jobs a good un mate 1 thing i will add is you would probably be best off with an impact air gun as the pulley take alot to crack off anything else i can help you with just drop me a pm or reply 2 this post cheers
mk3ste
17-10-2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
03-10-2015 10:44 PM
The Enigma
29-09-2015 10:31 AM
Nick 172 Sport
28-09-2015 07:21 PM
BENJAMIN_21
Ford Fiesta
17-09-2015 08:58 AM
Quick Reply: 2.0 306 hdi rattle till 3000rpm then clears........
